Headlight low beam plug melted
Old Nov 11, 2013 | 03:31 AM
Hotdawwgman's Avatar
Hotdawwgman
Cruising
Default Headlight low beam plug melted
I need some help trying to find a low exam headlights plug... Looks like it melted. Where can I find a replacement to solder one in? I don't want to buy a whole new harness for one plug
Car is a 2001 Convertible... Please help guys
Old Nov 11, 2013 | 07:45 AM
sunchaser73's Avatar
sunchaser73
Try EFI Connection.
Old Nov 11, 2013 | 08:35 AM
MAC5's Avatar
MAC5
They are available at almost all auto parts stores, Advance, Autozone, NAPA, etc. for a few dollars.
example:
http://shop.advanceautoparts.com/web...cket+connector
There is also a (heavy duty) high temp version if your interested
Properly splice it in and your back on the road.
Old Nov 11, 2013 | 11:59 AM
Hotdawwgman
Cruising
Thank you guys.. Any reason why it would melt?
Old Nov 11, 2013 | 12:31 PM
chris308's Avatar
chris308
Arcing due to loose connection would be my guess.
Old Nov 11, 2013 | 04:18 PM
MAC5's Avatar
MAC5
Originally Posted by 8VETTE7
Another possible cause is over wattage light bulbs that a previous owner may have installed...........
Concur with above and Chris308's comment on loose connection. Over the years I've had to replace one connector in both my 2001 & 2005 Jeep Grand Cherokees. Only thing in common was both were on the low beam and I was running Wagner Truview headlight bulbs (correct wattage). Up until I installed Radioflyers ACA HID setup last month, ran the Wagner's in the 98 C5 for years without any problems.
Old Nov 12, 2013 | 05:17 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Curious, were you using factory bulbs or aftermarket?
To Headlight low beam plug melted
