Clunking in Rearend
Old Jul 7, 2002 | 04:42 PM
bluebonnet's Avatar
bluebonnet
Default Clunking in Rearend
Has anyone experienced a heavy clunking noise in the rearend on an 01 MN6? It's had a clicking noise for months, and was at the dealer twice to no avail. The dealer replaced both lower control arms and then declared themselves befuddled with the continued clicking. In any case, today it began clunking, most predominantly during turns. Also, when in neutral, you can hear a faint grinding noise (with your ear next to the wheel). Really unpleasant sounding. To top it off, the top (convertible) leaked like a sieve during our heavy rains in the last week. So, I get to take a sodden, clunking Vette to the dealer tomorrow. Does anyone have any recommendations on what I ought to do vis a vis the dealer? (besides the obvious, which is to throw a fit). Appreciate any advice. thanks
Old Jul 8, 2002 | 09:46 AM
ncvetteman's Avatar
ncvetteman
Default Re: Clunking in Rearend (bluebonnet)
Does it happen more during slow parking lot manuvers (slow turns)?... I have clunking and some scrubing, I'm pretty sure its the limited slip rear end not releasing on turns. I'm taking it his week to have the fluid changed (I had a rear end leak and think the dealer didn't add the limited slip lube back), if that doesn't work I'm going to try aftermarket synthetic fluid (Redline or Amsoil), they have the limited slip additive built in.
Old Jul 8, 2002 | 09:54 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
sounds like you have serious problems. Be sure the car does not leave the shop till it is fixed correctly. :yesnod:
vetterdstr :cheers:
Old Jul 8, 2002 | 10:20 AM
2kbluestreak's Avatar
2kbluestreak
Default Re: Clunking in Rearend (vetterdstr)
I had a '78 that developed clunking in the differential every couple years. Sounded like a couple of bolts getting ground up by the gears; really bad. All it took to fix was the addition of the GM Positraction additive. Once you are used to this, the anxiety goes away. :yesnod:
Old Jul 8, 2002 | 11:57 AM
bluebonnet's Avatar
bluebonnet
Default Re: Clunking in Rearend (2kbluestreak)
Thanks for the advice. I'll let everyone know the outcome. cheers
Old Jul 8, 2002 | 04:42 PM
GraveDigger's Avatar
GraveDigger
I am experiencing the very same thing by the sound of it. Mostly manuvering in parking lots in and out of the driveway etc. It is a very same clunck. I added redline gear oil last weekend, but it still does it. If you solve the delima let us know.
:confused: Tod
Old Jul 8, 2002 | 10:40 PM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: Clunking in Rearend (GraveDigger)
I would check to be sure the rear sway bar is properly torqued at the ends and the mounts.
Old Jul 8, 2002 | 10:43 PM
John Wiz's Avatar
John Wiz
I had an intermittent clunk from my rear, usually heard during slow speed turns (parking lots, turning into the driveway). Turned out to be one of the end links was loose. I had someone start to do my exhaust, I wasn't happy with what he was doing so I had him stop. Anyway he didn't tighten one of the end links enough. It needed an allen wrench on the one side, and I cranked down as hard as I could (it was loose anyway). The was it. I did not have any grinding or anything else, though.
Old Jul 8, 2002 | 10:47 PM
GraveDigger
Default Re: Clunking in Rearend (John Wiz)
That could be my problem. When I installed my Coras, I started to loosen the sway bar and found I did not have the proper tools so I ended up cutting the stock pipes off.
Tod
Old Jul 8, 2002 | 11:06 PM
John Wiz's Avatar
John Wiz
Yep, probably is. You can break the upper link loose with just a wrench, but you need and allen wrench on the one side to get it tight.
Wiz
Old Jul 9, 2002 | 01:28 AM
bluebonnet's Avatar
bluebonnet
the dealer couldn't get it in today.......i'm printing everybody's suggestions/comments etc so they can have a headstart. thanks for the input. i'll let you know the outcome. jc
To Clunking in Rearend
