Do Tunnel Plates Really Make a Difference?
Old Nov 14, 2013 | 06:28 AM
s'noJob's Avatar
s'noJob
Default Do Tunnel Plates Really Make a Difference?
Caught this post about tunnel plates in another thread, (thanks, RedZMonte,) and am wondering, do they really affect handling enough to notice?
I have C6Z51 sways and Bilstein HD shocks. My tuner mentioned adding a tunnel plate.
What has been your experience with tunnel plates?
UPDATE 11/14/13: Tell us what suspension upgrades you made before adding the tunnel plate.
Old Nov 14, 2013 | 06:44 AM
NukeC5's Avatar
NukeC5
I have the C6 plate on my 99. I'f it did anything its minimal. But you have to consider.. they made them thicker for a reason.
Old Nov 14, 2013 | 07:02 AM
87SAM's Avatar
87SAM
When I added headers to my 2000 FRC I also added a 1/4 inch ceramic coated tunnel plate. I thought there was a noticeable difference in the feel of the car (while cornering) and it used to moan when driving over wide speed bumps but, not afterwards. Also did not feel any extra heat after the header install.
Old Nov 14, 2013 | 07:35 AM
Mickeyrx70's Avatar
Mickeyrx70
I added the thicker EE tunnel plate with thermal insulation with a header install. I couldn't tell any difference in ride, but heat protection seems good.
Old Nov 14, 2013 | 08:34 AM
chaase's Avatar
chaase
St. Jude Donor '12
I added the tunnel plate to my vert when all of the work was done to it. There was some reduced flex when going into and out of my driveway and other turns like it. There was a significant reduction in the console temperature.
Old Nov 14, 2013 | 10:16 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
Added an aftermarket plate, instant reduction in cowl shake! Whole car feels more solid, less overall vibration on the road. I'd say it should be the first mod, and a good opportunity to add extra heat insulation inside the backbone.
Old Nov 14, 2013 | 11:03 AM
SG Lou's Avatar
SG Lou
Same here !
Old Nov 14, 2013 | 12:45 PM
lionelhutz's Avatar
lionelhutz
I installed a 1/4" plate when the car was apart. I got it for $100 so not a big expense. But, I didn't think it did a whole lot. To me, it was certainly not a massive improvement like I've read in some posts.
Old Nov 14, 2013 | 02:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Same for me.
I have a ZO6 and they are a little stiffer car to begin with.
Didnt really notice all that much difference.
Yes there was a little more heat reduction.
BC
Old Nov 14, 2013 | 06:22 PM
s'noJob's Avatar
s'noJob
Well, so far the results seem mixed. Some of you felt improvement, some not so much.
I imagine it might depend on what you have on the car to begin with. A C5 with heavy suspension mods or a base Z06 or Z51 might not notice the difference as much as a bone-stock coupe or vert after acquiring a new tunnel plate. That's why I mentioned my C6Z51 sway bars and Bilstein shocks. It would be interesting to know what owners already had on their car before the plate upgrade.
Still, as NukeC5 pointed out, they made them thicker for a reason - it would seem that any improvement, whether noticeable or not, is still an improvement. A chassis that is 4% stiffer, let's say, is still stiffer and will help stabilize the car better.
One constant I noticed was the heat resistance. I don't have headers, but if I ever do plan on getting them, it sounds like I should get a plate with the insulation.
Old Nov 14, 2013 | 07:04 PM
NukeC5's Avatar
NukeC5
Thats a very good thought. I do have Pfadt coilovers and heavy rate sway bars as well as the poly bushings. Im sure the plate would be more beneficial if I didn't already have a top notch suspension.
Old Nov 14, 2013 | 07:13 PM
WICKEDFRC's Avatar
WICKEDFRC
Got mine from TPS Motorsports. 1/4" and while the material is stronger, I am not so sure it made a difference I can actually feel. But, I am certain the 1/4" thickness serves a purpose over the flimsy stock tunnel plate.
Also, got a respectable discount as a Forum member as well.
Old Nov 14, 2013 | 07:23 PM
lionelhutz's Avatar
lionelhutz
Why would it make a bigger difference on a base car vs an upgraded car????
Old Nov 14, 2013 | 07:25 PM
s'noJob's Avatar
s'noJob
It wouldn't make a structural difference. It might make an "apparent" seat-of-the-pants difference, though.
Old Nov 14, 2013 | 07:26 PM
LoneStarFRC's Avatar
LoneStarFRC
An economical alternative to a thicker aftermarket plate would be to double-up on the stockers. The stock fasteners are long enough.
A number of years ago, when C5s were still being manufactured, and aftermarket tunnel plates were all the rage, I recall seeing a few posts from people going this route.
Many stock plates get trashed when people buy the thicker plates and then have no use for their old one. Salvage yards also sell them of course too, so they're generally pretty cheap. Maybe even combine a C6 and a stock C5 plate.
Even if going this route, I would still recommend the heat insulation, such as Elite's Thermal Abs, or Thermo-Tec's product etc. Even when used on stock plates, the heat reduction is significant.
HTH
Old Nov 14, 2013 | 07:31 PM
s'noJob's Avatar
s'noJob
Good idea, but for racers, where every ounce counts, I imagine the aluminum ones are lighter.
Old Nov 14, 2013 | 11:09 PM
lionelhutz's Avatar
lionelhutz
A C5 with a stiffer suspension setup would transfer more forces into the chassis so why wouldn't it be more apparent then?
Also, I don't think a 1/4" or 3/8" thick Al plate will be much if any lighter then the stock plate.
To Do Tunnel Plates Really Make a Difference?
Old Nov 15, 2013 | 05:46 AM
s'noJob's Avatar
s'noJob
When I said it wouldn't make a structural difference, I meant between a base and an upgraded car. The plate would add 4%, let's say, more structural stiffness to both vehicles. But that 4% may seem more apparent on a base vehicle than on one that is already say 25% stiffer than the base.
And by lightness, I was referring to the practice of mounting double steel stock plates. A 1/4 inch Al plate would be lighter than two 1/8 inch steel plates.
Old Nov 15, 2013 | 08:19 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Actually, I think it might be the other way around. A car with less flex in the suspension will transmit whatever flexing forces it can, directly to the structure of the car. Therefore, a softer suspension will soak up more of the flexure in the suspension itself.
Having said that, I have an '01 coupe, with the selective suspension, and added one of those tunnel plates to it a LONG time ago. I really don't remember if I noticed any difference in stiffness, but from an engineering standpoint it makes sense....
Old Nov 15, 2013 | 10:27 AM
Gordy M's Avatar
Gordy M
When you look at the structural rigidity of the cars, the vert was somewhere at 22, the coupe at 24 and the FRC was close to 26, according to GM. With that in mind, you might find some additional rotational stiffness to the vert, minimal to the coupe and negligible to the FRC. As I recall, the tunnel plate was originally to keep the road debris from the exhaust and undercarriage.
