short or long tubes for cai
Old Nov 14, 2013 | 09:04 AM
wlean99's Avatar
wlean99
St Jude Donor '14
Default short or long tubes for cai
Hi Guys I have been researching a cai for my stock 99 C5.Originally liked the vararam set up but seems problematic. I have read info about "short and long tube" set ups and am confused as to why everyone wouldn't just use a long tube set up i.e.: actually drawing in COLD air versus a short tube which pulls in the hot air around engine as well.Does the longer tube sacrifice gas mileage for h.p. Does a short tube high flow system w/ large air filter really add any h.p or does it just "sound better" when stomped on.(placebo).What would be the best choice for just cruising around,not drag racing the car,but definitely driving as it was built to be driven.+ would I need to change the mafs to accommodate more air intake?
Old Nov 14, 2013 | 09:38 AM
Zorlac's Avatar
Zorlac
Short/long tubes are headers. Not related to a cold air intake system. Unless I just read your post wrong.
Old Nov 14, 2013 | 10:08 AM
wlean99's Avatar
wlean99
St Jude Donor '14
yes Zorlac,you have misread my question,not talking about headers perhaps I should have said short or long "tube" on a cold air intake system.Any advice thanks
Old Nov 14, 2013 | 11:48 AM
Zorlac's Avatar
Zorlac
The Vararam and Callaway in my opinion are the best CAI out there. They are two different methods to get cold air but both work well. My Vararam I'm sure gave some HP but it did make the throttle response more crisp. After a tune from ECS my A4 really woke up with the Vararam and Corsa exhaust. The stock maf is fine for a CAI. Without a different cam, heads supercharger etc a stock motor is only going to suck so much air.
Old Nov 14, 2013 | 12:51 PM
Cybermind's Avatar
Cybermind
I would go with an upgraded Z06 airbox and open up or remove the foglight shrouds. You end up with a much improved intake (compared to a 99), more cool air to the engine and a stock look.
In my opinion and based on my experience, most so-called CAI systems are over rated. You don't get much of a performance gain at all and in some cases, you end up losing torque.
Varraram has proven itself to work on the track but it has horrible fit and made with the cheapest materials possible. Every one I have seen installed, had a leak somewhere. Most of the time, the owner never even realized it until I pointed it out. I'm not saying to not get one, but be ready to do some fabricating to get it to fit and seal properly.
Old Nov 14, 2013 | 03:44 PM
Dave68's Avatar
Dave68
"Short ram"-type intakes are almost always not true CAIs, so you are correct in thinking that way. The OEM intake filter assembly is positioned far forward to get the filter away from the engine. Cybermind is correct in that opening up the fog light panels, along with replacing or modifying your filter box will definitely pump up the HP. Adding a heat exchanger hood will also help, as well as a better flowing cat-back.
Most data loggers that plug into your OBDII port will display intake air temperature. You can get a baseline and then go from there to see how mods keep those temps down.
Old Nov 14, 2013 | 05:17 PM
RedZMonte's Avatar
RedZMonte
Both a Cold air intake (I like Callaway Honker) and a Open filter (Like a Blackwing) will perform simmilar. If my Z06 didnt have a intake allready on it (Breathless Performance Vortex Rammer) i would go for either a Callaway Honker or Haltech. I also replaced the stock Air bridge going over the Radiator, read that the stock one collapses a little under HEAVY accel and chokes the intake down.
Idealy Cold air intake with a Isolated filter from the engine bay is best, but once the car is moving the hot air is drawn away from the filter so you would see most gains if the car goes from a stop (like a Drag Strip). even then the differences are minimal, becuase both will eliminate some restriction from the stock air box.
Old Nov 14, 2013 | 07:02 PM
wlean99's Avatar
wlean99
St Jude Donor '14
dave 68,red monte and all others that responded to my cai question,thanks for your input I am looking at a new product made by lgm that has a bigger bellows and large air filter. However seems to have a short tube,suppose I can always play around and add a longer tube to get the filter down by the radiator as well as adding some holes in my stock fog light panels.p.s system is more than 1/2 price of callaway,and blackwing set up.
Old Nov 14, 2013 | 07:57 PM
Blow Torch's Avatar
Blow Torch
Going to have to respectfully disagree. The cooler the air, the more dense it is and the more power it makes, Car makers have always know this (shaker hoods) as well as drag car builders (how many DON'T have hood scoops)
Anyone that has driven a Vette with a vararam on a 40* morning, will know of which I speak
Any time you can bring outside air directly to your carb or TB, you are going to see some performance increase.
Lose torque??? How is that possible??
Old Nov 14, 2013 | 08:06 PM
wlean99's Avatar
wlean99
St Jude Donor '14
blow torch .I concur,I am going to try and stuff my set up as close to the opening as the stock placement under the hood as possible.Will probably have to make custom tube..be surprised what you can find in the plumbing section of home depot.lol
Old Nov 14, 2013 | 10:01 PM
Dave68's Avatar
Dave68
...or you can do what I did and make your own cold air scoop setup. See:
http://www.conceptualpolymer.com/Rad...op%20inst..pdf
Old Nov 15, 2013 | 04:58 AM
Cybermind's Avatar
Cybermind
I think you misread my answer. I am referring to "so-called" CAI's that are sold as such but in reality are just a large gauze type filter or filters mated to an air bridge. These are not "true" CAI's and all you end up with is hotter underhood air being ingested into the engine. Yes, you probably will end up with lower torque and sometimes lower HP numbers under certain conditions.
I agree with you regarding true Cold Air Intakes that take the air from outside the engine compartment. That is why I mention the Varraram.
Old Nov 15, 2013 | 06:44 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Default dave68
and others thanks for input.dave thanks for uploading video about cold air box very interesting couple questions,saw this was done in 2004,how did the plastic letter holder hold up under engine heat? and if you could look at this cai and give me an opinion on weather its worth 185$.ITS AT LGMOTORSPORTS.COM PART # 32118195530.ON FLEA BAY .THANKS
Old Jan 12, 2014 | 04:41 PM
chuckeb84's Avatar
chuckeb84
Just saw this...Very impressed with the details!
Old Jan 14, 2014 | 08:07 AM
strand rider's Avatar
strand rider
Just because you can, doesn't mean you should.
What is the problem with the stock intake that is buggin' you. Any solution starts with identifying the problem.
I think for a lot of people , the only intake problem they have is that it is stock, and not "special".
Old Jan 14, 2014 | 06:16 PM
wlean99's Avatar
wlean99
St Jude Donor '14
Strand rider,this is a rather old thread I started.Ultimately after some issues,w/aftermarket set up,I went back to stock set up, :just left well enough alone. Sometimes" the enemy of good is better".
To short or long tubes for cai
