Turn signals intermittent
Old Nov 21, 2013 | 12:52 PM
Jake Merchant's Avatar
Jake Merchant
Default Turn signals intermittent
Help! My 2000 C5 has developed a turn signal problem. The signals work and then stop. Pushing in on the emergency flasher switch X 2 temporarily resets the signals. My tech says there is no fix. Any of you have the same problem?
I also have active ABS/traction control and the module has gone out. Naturally, GM does not manufacture them since the "strike" nor do thye stock any. Know of any places to search?
Old Nov 21, 2013 | 10:30 PM
formerfoxbody's Avatar
formerfoxbody
find a new tech, replace the hazard switch. there are threads about how to do this without removing the dash pad and it's pretty easy to do.
Old Nov 22, 2013 | 05:57 PM
Jake Merchant
Default Codes For My Vette
99 - HVAC - Bo338 - H
99 - HVAC - B0361 - H
60 - IPC - B0516 - H
58 - SDM - U1000 - HC
28 - TCS - No Comm.
10 - PCM - P1571 - HC
None of the codes would clear with the reset button.
To Turn signals intermittent
