Coolant over temp. Please help!
Old Nov 30, 2013 | 12:52 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by Evil-Twin
Don't waste your money on finding out what is wrong????? seems like poor advice to me.
change the tank? suppose it's one of the ten other things it could possibly be.
Many people from the 60 or who have 1960's automotive mentality, throw parts at a problem in the hope that sooner or later and after wasting lots of money replacing good parts with new parts until you stumble on the problem.
it could be a blocked condenser, could be a blocked radiator, a bad stat, a bad pump, a leaking tank at the joint or a leaking line, a blow head gasket, a bad sensor, air in the coolant line, a bad radiator cap a glitch in the BCM, a bad fan , a fan that has sucked in a plastic bag.
The right answer is to find out what is wrong not throw parts at it.
Well he stated it was leaking at the tank and the shop wanted a hundred bux to diagnoise the leak. If he knows its leaking at the tank replace the tank.
So my advice was correct. Saved him a 100 bux
Old Nov 30, 2013 | 12:59 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by LoneStarLizzard
As always, Bill (ET) gives sage advice. To do other than he suggests is, as I tell my kids, kinda like, "I have the answer. Now, what's the qeustion?"
The Lizzard
AND as always he does not pay attention when he reads. THE op clearly stated a leak was at the surge tank as most of us know the nipple cracks.
Originally Posted by sam-garcia
I checked the coolant level and it was way down. I did noticed coolant seemed to have sorta sprayed on top of the surge tank but no visible leaks?! \
Old Nov 30, 2013 | 01:08 PM
Corvette_Ed's Avatar
Corvette_Ed
I think ET's point is to verify where the problem is before buying parts for it, no matter how likely you think it might be a specific problem. The OP had not yet done so when ET posted his advice. It could very well have been a hose that was leaking, which would have wasted all of the money spent on a new tank.
