Spark plug wires grounding to headers?????
Old Jul 10, 2002 | 08:04 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Spark plug wires grounding to headers????? (MiamiDave)
I just got my MSD wires from Summit and boy are they pretty! :D 440rwhp here we come! :smash:
Phillip :cheers:
Old Jul 10, 2002 | 08:54 PM
MiamiDave's Avatar
MiamiDave
Default Re: Spark plug wires grounding to headers????? (Phil97SVT)
Thanks guys, but which Vendor has the best price for MSD, NGK, and KoolSox Sleeves?
Old Jul 10, 2002 | 09:05 PM
Johnno's Avatar
Johnno
I'm not taking any chances - having a LPE magnuson S/C installed right now and I'm going with Swaintech coated headers (a true ceramic coating), MSD wires, stock metal sleeves, and using Koolsox plug wire sleeve protectors. I figure that should nip any potential heat/grounding problems in the bud... :D
[Modified by Johnno, 7:05 PM 7/10/2002]
Old Jul 11, 2002 | 07:23 AM
MiamiDave's Avatar
MiamiDave
Default Re: Spark plug wires grounding to headers????? (Johnno)
Are you going to do that for the supercharger as well? ;)
I don't blame you. These C-5's can get brutally hot, and your S/C is probably not going to help.
Have you considered bigger radiator/thermo/fans as well?
Old Jul 11, 2002 | 11:40 PM
Johnno's Avatar
Johnno
Hi MiamiDave,
I've added redline water wetter and a lower temp thermostat to it already. I've asked LPE to also dial-in a lower temp radiator fan kick-in setting when they flash my computer during the tuning phase of the S/C install.
I realize that the S/C will add quite a bit of heat (when it's boosting that is), but since I don't plan on tracking the car, I don't think I'll need to look at a bigger radiator. Luckily, I also live in Minnesota, so high temps outside are pretty rare most of the driving season... love those cool Autumn days here... lot's of traction issues with that cold/dense air... but in a good way. :D
Old Jul 12, 2002 | 03:36 AM
tito's Avatar
tito
i fried 4 plug wires due to no socks. I junked the taylors and bought some MSD's and a set of Taylor socks.. its the only cure to this problems, unless u buy header wrap and that would just be reversing the role.
