Yaw adjustment?
Old Nov 25, 2013 | 05:45 PM
Sox-Fan's Avatar
Sox-Fan
Default Yaw adjustment?
Ran into a situation in an Autox this weekend where we got the car out of shape a bit and the car just shut off. 2004 z06.
Well, maybe more than a bit, but not to the point where it was going to turn itself around. And it just shut the engine off. Still had electrical power, dash lights, etc. Just shut off the engine. Did not stall the car. The engine shut off. Is there some sort of yaw sensor that is maybe adjustable that we can look at?
I'm also wondering is there a way to turn off all the nannies? Seems trac OFF leaves the ABS ON, and Competition mode keeps active handling ON. Did I miss a way to get ABS and traction control off?
Old Nov 25, 2013 | 05:58 PM
racebum's Avatar
racebum
fuel starvation is probably what did it, and or the rpms dropped enough to seize the motor when you spun around and you didn't realize it.
happens with nearly any street car in that situation. i've done it in vettes, hondas, mustangs,
has nothing to do with what you're suspecting
the abs isn't slowing you down, the other two certainly can though
if you have trac and active handling off you're as good to go as can be expected
Old Nov 25, 2013 | 06:04 PM
Sox-Fan's Avatar
Sox-Fan
Ok, thanks. To be clear, the car didn't spin. Did get very sideways but as soon as the engine shut off it straightened right up. Stopped the car, engine fired up, drove away. tires were free wheeling. Wouldn't have expected a stall under those circumstances.
To Yaw adjustment?
