Help! Shift from 1st to 4th gears???
I'm totally lost on this subject. I've read a lot but yet confused. My owner's manual says that when this indicator light comes on you must immediately shift from 1st to 4th. If not, you run the risk of damaging the engine. Damaging the engine??? Huh?
I DO NOT get locked out of 2nd and 3rd gears. I've read a lot about the CAGS eliminator option, but I don't believe it applies to my car.
So, under these driving conditions, do I just ignore the dash shift light and gear & brake as needed in traffic OR do I shift from 1st to 4th and heavily bog down the car? Of course, I DO NOT WANT TO DAMAGE MY CAR!
Thank you.
If you have a light on the dash.... but can still go into 2nd,,,, someone has put the eliminator in it already.
worst you will do is stall if you bog down to much going from 1st to 4th,,,, I cant see a scenario where you would do damage.
I would ignore the light,,,, and do what is right for the conditions you are in
It only happened when I was just puttering around.
When I got on it hard it would not happen.
I got a CAGS eliminator and it allowed me to shift to any gear I wanted.
I think (not sure) that the tuners can tune this out of your car as well.
Toque
Toque
============= Cut 'n Paste from OM ===============
One to Four Shift Light
(Manual Transmission)
When this light comes on,
you can only shift from
FIRST (1) to FOURTH (4)
instead of FIRST (1)
to SECOND (2).
You must complete the shift into FOURTH (4) to turn
off this feature. This helps you get the best possible
fuel economy.
After shifting to FOURTH (4), you may downshift
to a lower gear if you prefer.
NOTICE:
Do not try to force the shift lever into SECOND (2)
or THIRD (3) when the 1 TO 4 SHIFT light
comes on. Do not try to re-engage FIRST (1)
after starting to shift into FOURTH (4). You will
damage your transmission. Shift only from
FIRST (1) to FOURTH (4) when the light
comes on.
This light will come on when:
The engine coolant temperature is higher than
169F (76C), you are going 15 to 19 mph (24 to 31 km/h)
and you are at 21 percent throttle or less.
It's easy to drive around the 1 to 4 shift light, but putting in a CAGS eliminator makes it so you don't have to worry about driving around it all the time.
Compliance parts also has a skip-shift eliminator that is installed in the underhood fuse box, and it can be additionally configured to eliminate the dash light entirely - no need to get under the car to disconnect the solenoid or install a resistor plug at that location.
The entire set up cost around $800. so,,, most people go to shops that tune the PCMs on GM cars and trucks.
There are hand held tuning devices but they are limited in what they can tune or change.
BC
It looks like somebody already disconnected your lockout solenoid, which is why you can freely shift even when your 1st to 4th dash light is on.
In that case, as long as you don't get any check engine lights, just ignore the 1st to 4th shift light on the dash. Just shift the car as you normally would.
If the skip-shift light comes on, but allows you to go to 2, you have a CAGS eliminator.
If no light comes on, and you can go to 2 freely at will, she's been tuned.
If you unplug the CAGS, you an shift to two as well, but will play absolute HELL trying to get the car into reverse. It's not good for the Trans at all.
Just something to consider...
... WTH does that mean?
