Header gaskets
Old Nov 27, 2013 | 09:48 AM
Cedarberry's Avatar
Cedarberry
Default Header gaskets
Just wondering if there's a set of header gaskets that most prefer, any input greatly appreciated
Old Nov 27, 2013 | 09:59 AM
StatmanRN's Avatar
StatmanRN
Over the years and other vehicles I have become a big fan of copper gaskets with Permatex spray copper sealant and locking bolts. Interested to hear any LS specific recomendations.
I'm about to install a set of Sanderson headers on my lincoln Mk IV 460. They say to use NO gasket, just high temp silicone because of their flange design. We'll see how that works out.
Old Nov 27, 2013 | 10:12 AM
7LitreC5's Avatar
7LitreC5
I always use the stock LS gaskets. They don't cost much and seal perfectly every time.
Old Nov 27, 2013 | 10:29 AM
Dcollins3208's Avatar
Dcollins3208
yep the stockers are great, just picked up a set from the dealership a few weeks ago, about $30 for the pair i think
Old Nov 27, 2013 | 11:26 AM
Kreeess's Avatar
Kreeess
yep stock GM gaskets will be more than perfect
Old Nov 27, 2013 | 02:49 PM
The Void's Avatar
The Void
+1 on the stock multi layer steel gaskets. I bought new gaskets for the h/c/i swap and did not like the bolts ability to snug them up. Swapped to studs and reused the new gaskets. With studs and mls gaskets you cant ask for any better sealing.
Old Nov 27, 2013 | 03:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
+2 MLSS Stock OEM gaskets! Used several aftermarket ones and none hold up better than the OEM Metal gaskets.
BC
Old Nov 27, 2013 | 03:55 PM
LoneStarFRC's Avatar
LoneStarFRC
BC
+6 on the OEM GM steel gaskets. Never once had any issues.
Old Nov 27, 2013 | 04:28 PM
Cedarberry's Avatar
Cedarberry
Thanks guys, OEM it is
Old Nov 27, 2013 | 05:47 PM
Tech's Avatar
Tech
Be sure to get the gaskets with round ports if you have headers. They came on 1998-2002 Camaro Z28s. I know some C5 gaskets are D-shaped (perhaps just LS6 engines). If you get the Camaro gaskets you'll be sure they are correct.
Old Nov 27, 2013 | 09:37 PM
Blow Torch's Avatar
Blow Torch
Yep
Just use the same ones you took off
To Header gaskets
