Body Side Moulding
Old Dec 4, 2013 | 08:52 PM
xzo124's Avatar
xzo124
Default Body Side Moulding
What is best way to remove BSM ??...xzo
Old Dec 4, 2013 | 09:16 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The best product is a heat gun and waxed dental floss. A heat gun can be dangerous so a hair dryer is safer but less effective.
Old Dec 4, 2013 | 10:19 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Mechanix gloves
50 lb fishing line
Spray can of Goo Gone/goof off.
Spray the goo gone along the top side of the piece of molding you are working on then cut through the tape under the bsm's with a sawing motion. If you aren't concerned with resale of the bsm's. angle the fishing line back toward you away from the car while sawing.
Start with a shorter piece to get your technique down(front fender). As you get a few inches help separate the molding by applying stress to the tape pulling the molding away from the car a bit. Once you get a piece off there will be tape left on the car and it will look kinda scary. Apply more goo gone and rub with your gloved fingers as you would rubbing a sticker into a ball. Should all come off with some elbow grease. Hopefully your paint is A okay.
Good luck and post before and after pics
P.s. when you spray the goo gone i would apply it along the top of all pieces and let sit. Really saturate it so the job will be easier. Victory loves preparation/work smart not hard kinda thing
Old Dec 5, 2013 | 04:41 AM
65GGvert's Avatar
65GGvert
If you want to read articles, with pictures on removal (and there are hundreds), go to Google and type in C5 BSM removal, or C5 body side molding removal, or similar. Google is much more productive than the forum search, but it still finds forum articles. You'll also see threads where owner's were surprised that their cars had been painted without removing the bsm's which can be a real issue, as 8Vette7 said.
Old Dec 5, 2013 | 05:21 PM
bluestreak63's Avatar
bluestreak63
Originally Posted by 8VETTE7
Are you sure you want to do that??? Many have found the door had been repainted without removing the BSM's and they had a real mess to deal with after removing the BSM's and others have distinct fading of the paint except under the BSM.
Last thing I would want, is to remove them only to find there is a slight color variation. Then having to put them back on, only to find they fall off down the road, because the sticky used wore off.
Old Dec 5, 2013 | 06:19 PM
guido7834's Avatar
guido7834
Leave em on. They look better anyway.
Old Dec 5, 2013 | 07:13 PM
Bluefire's Avatar
Bluefire
I respect your opinion. Mine opinion of them is
It's a Stealership added option to make money. Not part of the original design.
BTW, How many car doors actually line up with the BSM that would contact that molding. Not many that I know of.
Old Dec 5, 2013 | 07:46 PM
SG Lou's Avatar
SG Lou
Fishing line used between the side moldings and the door. Use a sawing motion with the monofilament line.
I was one of the MANY that found out AFTER i removed the BSM's that the door was repainted.
Old Dec 5, 2013 | 08:08 PM
tbrent's Avatar
tbrent
Like everything it's just a matter of what will make a person happy... I didn't know what the paint was like until I removed mine. I lucked out. But, I knew going in that the door bumpers were coming off regardless. Had the paint been funny I would have just had them fixed. BSM's look hideous IMO.
Old Dec 5, 2013 | 08:35 PM
xzo124's Avatar
xzo124
Myself!! Have been around the car its intire life and know it has never been painted. Being White Im going for it . They look so much sleeker . Thats exactly the reason they make Chocolate and Vanilla ......xzo
Old Dec 6, 2013 | 06:03 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
No. They were a factory option.
Old Dec 6, 2013 | 07:47 AM
camburger's Avatar
camburger
BSM...I only discovered they were disliked by some when I joined this forum...prior to that it was merely part of my car...and never a concern really.
Old Dec 6, 2013 | 10:13 AM
Mattie Num Nums's Avatar
Mattie Num Nums
WD40 and fishing wire, then I just pulled them off. Can't even tell they were there.
Old Dec 6, 2013 | 01:52 PM
Z06seal's Avatar
Z06seal
they create downforce at high speeds, and that's a serious note to add. lol
I never removed mine because i'm afraid it will be different colors behind it. not taking the risk.
Old Dec 6, 2013 | 02:43 PM
jrose7004's Avatar
jrose7004
Yep, the car looks better without them!
Old Dec 6, 2013 | 04:31 PM
Bluefire's Avatar
Bluefire
I stand corrected. It was a useless factory option solely designed to make money.
Old Dec 6, 2013 | 04:48 PM
xzo124's Avatar
xzo124
Thats what Im talkin bout !! Nice Ride....xzo
To Body Side Moulding
Old Dec 7, 2013 | 11:23 AM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
80k miles on my z that sits outside.
Used fishing string and wd-40.
With a heatgun they came off really easy.
No color difference at all, plan on buffing the area due to wax buildup at the bsm.
Can post a few pictures I took during the process if you want.
Car looks so much better now
Old Dec 7, 2013 | 12:59 PM
xzo124's Avatar
xzo124
:iagree
...xzo
Old Dec 7, 2013 | 03:15 PM
Cybermind's Avatar
Cybermind
I'd love to remove mine but I just am not ready or willing to take a chance with what I find underneath. Oh well, maybe one day.
