Help: Service traction control/active handling
Old Dec 6, 2013 | 11:31 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Help: Service traction control/active handling
This message popped up after a few projects on the car (none of which involved the factory wiring)
ABS is still active. Mechanic with a tech 2 said it was brake switch open (code C1292 I think) but the brake lights come on and the brake pedal will disable cruise control. I do have LED brake lights so I'm curious if there's a minimum current needed in the switches?
Going to remove the switches tomorrow and clean the internal contacts for good measure.
Is this a code that needs to be cleared or will it go away on the next ignition cycle if I fix the problem?
PROBLEM SOLVED!!
The open switch code was caused by a combination of my LED tail lights (converted to euro) and the 3rd brake light being hooked up to a flasher. The current load of all of these hooked together was not enough to give a solid signal to the computer. I installed a load resistor on one of the tail lights and that fixed the problem.
Old Dec 7, 2013 | 08:41 AM
AWSOME 04's Avatar
AWSOME 04
I hate to be the"bearer of bad news," but this sounds like the steering position sensor.
I had the exact same thing on my 04. I have no clue as to why the steering wheel position sensor has anything to do with the traction control & active handling, but it does.
Good Luck!
Old Dec 7, 2013 | 04:55 PM
TheRadioFlyer
Supporting Vendor
Did some more research. Code is a C1295. Open brake light circuit.
I'm 99% sure it has to do with my LED tail lights. I run them without a resistor because I like hyper flash and I used the resistors as donor parts on customer's lights that had a problem. I recently did a modification to my 3rd brake light. I'm going to re-install a resistor on one of the tail lights and see if that fixes the problem.
edit: That was it. See OP for solution.
To Help: Service traction control/active handling
