Help with repairs -- C5
Old Dec 10, 2013 | 12:21 PM
smichener's Avatar
smichener
1st Gear
Default Help with repairs -- C5
I own a 2000 Black Corvette Convertible and was told that my main seal is leaking; however, I smell a burning oil smell after driving it a long distance. I am a single female and would greatly appreciate any recommendations for an HONEST mechanic in the Fort Worth, TX area. Thank you so much!!
Sherry Michener
Old Dec 10, 2013 | 01:47 PM
Eric ray's Avatar
Eric ray
Welcome Sherry, there are tech catagories in this forum, you may find the answers your looking for there. Good luck and welcome aboard.
Old Dec 10, 2013 | 04:23 PM
Pfadt Racing's Avatar
Pfadt Racing
oil pressure sender is a common leaking point. Try the tech section for some advice as well
Old Dec 10, 2013 | 06:50 PM
American Heritage's Avatar
American Heritage
Supporting Vendor
Try your regional section and post up your question there. You should get a response from a local CF vendor in no time.
Old Dec 11, 2013 | 06:15 AM
Cybermind's Avatar
Cybermind
Keep in mind that most of the time, oil pressure sender leaks are misdiagnosed as leaking rear main seals. This is due to the fact that it drips down the back of the engine and gives the impression that the rear main is leaking. You need to find a shop that specializes or at least knows Corvettes. Mechanics that have never worked on C5's will misdiagnose this problem 90% of the time. It could also be a leaking upper oil pan gasket.
To Help with repairs -- C5
