UGH!!! 1635 Code
Old Dec 18, 2013 | 04:48 PM
david1st's Avatar
david1st
Default UGH!!! 1635 Code
My 2 year old battery had to be replaced and have code 1635 C that won't clear......ugh!! Cold start up car shuts off but starts up on 2nd start up also low oil pressure
Old Dec 18, 2013 | 04:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Either you have a shorted 5 VDC Supply wire to the sensor or its open.
Check 5VDC on other sensors and see if they have proper 5 VDC. When I get home I will tell you what sensors to check.
Old Dec 18, 2013 | 04:54 PM
david1st's Avatar
david1st
Okay. Thanks Bill
Old Dec 19, 2013 | 05:14 PM
david1st's Avatar
david1st
Codes IPC 1160 HAVC 1160 popped up today but cleared out
Old Feb 28, 2014 | 08:27 PM
david1st's Avatar
david1st
Well I replaced my ignition switch today and still have 1635 code. I unplugged my oil sending unit and 1635 code is gone but now have oil sending unit code. Not sure it's the oil sending unit or a bad feed back. Ugh!!!
Old Feb 28, 2014 | 10:06 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Replace the oil pressure switch. The op switch and map share that 5v ref. You already diagnosed your problem by unplugging the switch and the code not resetting.
To UGH!!! 1635 Code
