Need recomendations for battery tender
Old Dec 21, 2013 | 03:19 PM
napacruzerc5's Avatar
napacruzerc5
Default Need recomendations for battery tender
Fortunately S.F. Bay Area weather let's me drive my C5 year 'round. But if I don't drive it at least every other week my battery goes dead. I have a 6amp charger but would rather have a battery "maintainer" so I don't have to charge as often. What's a good tender? Price range?
Old Dec 21, 2013 | 03:37 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I got mine at Autozone for 40.00.
http://www.autozone.com/autozone/acc...er=756181_0_0_
Works great
Old Dec 21, 2013 | 05:24 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
BatteryMinder 12248
http://batteryminders.com/details.php?prod=12248
You can find it a little cheaper on Amazon or elsewhere.
Been using for three years on all of my cars (I have one for each car) and no complaints. Best part is they can be used on flooded, AGM and gel batteries.
Old Dec 21, 2013 | 05:28 PM
2019 ZR1's Avatar
2019 ZR1
My 2013 came with one. Well it was a $100 option. I'm sure you could find one cheaper online.
Old Dec 21, 2013 | 05:46 PM
don hall's Avatar
don hall
Hook it up.... forget it:
Battery Tender 800 Waterproof 12V Battery Charger : Amazon.com : Automotive Battery Tender 800 Waterproof 12V Battery Charger : Amazon.com : Automotive
Old Dec 21, 2013 | 07:31 PM
phoneman91's Avatar
phoneman91
Are any of these suggested battery chargers/maintenance chargers American made? Or is there such a thing anymore?
Old Dec 21, 2013 | 07:51 PM
vettenuts's Avatar
vettenuts
I had two Battery Tenders go up in smoke. Never again will I buy their products. I now run the CTEK.
Old Dec 21, 2013 | 08:22 PM
seagem's Avatar
seagem
Ctek
Old Dec 21, 2013 | 09:23 PM
rodsvet's Avatar
rodsvet
I tried the battery tender a few years ago. The unit got hot and the battery would go dead. I just put mine on a trickle charge once a week and all is good. I don't need a fire in the garage to keep me warm, I live in California. Rod
Old Dec 21, 2013 | 10:44 PM
2019 ZR1's Avatar
2019 ZR1
Has anyone else used the one from Chevy???
Old Dec 21, 2013 | 10:55 PM
don hall's Avatar
don hall
Chevy? Which one might that be?
Old Dec 22, 2013 | 04:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 4XLR8N
BatteryMinder 12248
+1
It also contains desulphation circuitry, whereas most others do not.
Old Dec 22, 2013 | 09:32 AM
vettenuts's Avatar
vettenuts
Originally Posted by LoneStarFRC
+1
CTEK does as well.
Old Dec 22, 2013 | 09:34 AM
vettenuts's Avatar
vettenuts
That's what I found. I opened the garage to an acrid burnt electronics smell that was once my Battery Tender. The "Warranty Repair" cost $5 less than the cost new, so much for that. Then the new one went up in smoke again. Have been using the CTEK since then without any issues at all.
Old Dec 22, 2013 | 09:51 AM
dadaroo's Avatar
dadaroo
Get a Battery Minder or CTEK, not a Battery Tender.
Old Dec 22, 2013 | 09:19 PM
kennedy759's Avatar
kennedy759
I use the $20 one from walmart made by Schumacker, only problem is the ring connector only fits the bolt on top post batteries(I use one on my Mercedes), it is too small to fit a side post, so I called and they are sending me one, in the mean time I use the clamps, or I could buy the Battery Tender rings that fit a side post and also will connect to a Schumacker.
Old Dec 23, 2013 | 10:40 AM
TEXHAWK0's Avatar
TEXHAWK0
If you are not going to drive the car enough to keep the battery charged, I would remove the battery and fully charge it. Without parasitic loads, the battery should stay charged a lot longer between usage. I don't like leaving chargers plugged in and unattended for long periods of time.
To Need recomendations for battery tender
