Front end Squeak
Old Jul 10, 2002 | 02:00 PM
RockeVette95's Avatar
RockeVette95
Default Front end Squeak
When I hit a bump it makes a high pitched squeak sound seems to be coming from the left front area. I've heard lots of squeaks rattles and noises (former c4 owner :) ) Got any obvious ideas all you squeak and rattle gurus??
98 coupe
Old Jul 10, 2002 | 02:33 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Front end Squeak (RockeVette95)
The most common squeak is the frame mount bushings which mount the sway-bar to the frame. I would use some waterproof grease which doesn't eat rubber. Then pull the frame-mount bushings and grease the inside where the bar goes through. If that dosen't work then it's the a-arm bushings. If you have the rubber bushings there is no apperent fix accept for changing over to the polygraphite and greasing them real good when installing.
[Modified by VBP, 6:36 PM 7/10/2002]
Old Jul 10, 2002 | 03:32 PM
carpe dm's Avatar
carpe dm
VBP is probably right, but before you go to that much effort, put some grease on the rubber hood stops under the hood. Worked for me! :yesnod: :smash:
Old Jul 11, 2002 | 10:52 AM
RockeVette95
Default Re: Front end Squeak (carpe dm)
You Sir are worthy!!! greased the hood stops she's quiet as a mouse!!!!
Old Jul 11, 2002 | 01:00 PM
carpe dm's Avatar
carpe dm
Glad it worked for you. I have gotten so many helpful hints from this Forum, its nice to contribute too. :yesnod: :)
Old Jul 12, 2002 | 11:32 AM
RockeVette95
It's Baaaaack!!! probably the sway bar bushings when I lubed the hood stops I also sprayed Wd-40 on the bushings. They probably dried out already. Will try some spray grease maybe??
Old Jul 12, 2002 | 11:47 AM
carpe dm's Avatar
carpe dm
Oh no! :cuss Son of a gun....... Valvoline makes a great synthetic spray lube that might help. Hope you get it without the "disassemble" process! :smash: Good luck.
Old Jul 12, 2002 | 01:12 PM
RockeVette95
I used to live in Apache Junction love the desert. Thanks for your advice!!!
To Front end Squeak
