Radio interference when brakes are applied
Old Dec 30, 2013 | 04:42 PM
General Lee's Avatar
General Lee
Default Radio interference when brakes are applied
This just started, when i apply the brakes the FM radio cuts out and replaced by static didn't check the AM band,any ideas?
2004, all the lamps illuminate, signals work,
Iv been running a Kenwood HU and back in the spring i changed the tail over to LED's never had a issue until last week
TIA.
Old Dec 30, 2013 | 07:27 PM
ZR1X's Avatar
ZR1X
Default Seen it with LEDS
TIA.
go back to stock bulbs than check.
Old Dec 30, 2013 | 08:39 PM
jcgunn's Avatar
jcgunn
It's the LEDs. I had all kinds of weird stuff happen with LED brake lights. No problem with switchback LED DRLs, but I gave up on the LED brake lights. Too much crazy stuff (DIC dimming, DRLs going out with brake pedal depressed, etc.)
Old Dec 31, 2013 | 12:44 AM
General Lee
ok guys, I'll switch back to the stock bulbs and see what happens, crazy though it didn't happen right away, wonder what causes it.
Old Dec 31, 2013 | 05:35 AM
Jeffwilson34's Avatar
Jeffwilson34
I never had good reception in mine, LED's made it worse.
I installed several "guaranteed" antennas with boosters and such.
I even temporally mounted a normal one in the hatch area.
My best luck was a FIN type that looks like the antenna on some navigation or onstar units systems in some cars.
I finally gave up and found a great solution.
A head unit with Bluetooth, an Iphone with unlimited data plan and several streaming online stations or apps. I can listen to all local stations plus comedy stations, old time radio serial stories, news from around the world and almost anything a satellite radio would pick up. all free sans the data I already pay for.
I am almost ready to go with a head unit that has built in WIFI and windows mobile and use my phone as a wifi hotspot. I saw one in use and it would stream HULU, youtube, and netflix on a 7 inch poop out single din head unit.
Plus it has built in navigation and external camera inputs.
To Radio interference when brakes are applied
