C5 Constant Horn Beep
Old Dec 30, 2013 | 10:00 PM
R Mackow's Avatar
R Mackow
Default C5 Constant Horn Beep
It wasn't Santa on the roof!
At 4AM on 12/26/13, my 2000 C5, which was sitting in the driveway, decided it wanted to sound off with a continuous horn beep.
I'm not sure if this was in protest over several months of being ignored ( I've been helping my daughter remodel her house for the last several months.) Before I opened the hood and disconnected the battery cable, I tried to start it with a key to my GMC Envoy. After I realized it was the wrong key I tried the correct key and car would not start, so went for the battery cable.
My security setting were set to have lights blink and horn NOT to sound. This I believe is another issue. Anybody experience this or know what's going on? I keep the battery on a trickle charger and do run the engine to get it operating temps during the last several months.
Old Dec 31, 2013 | 07:53 AM
msu-dawg's Avatar
msu-dawg
Originally Posted by 8VETTE7
Your problem is likely the horn membrane switch. Both summer heat and winter cold cause the problem.
Read here:
http://forums.corvetteforum.com/show....php?t=1739923
OR here
http://tech.corvettecentral.com/2012...rn-switch-fix/
I was going to suggest the same, based on similar personal experience. But I don't see any reason that the horn membrane switch would have caused the car to not start.
