tire pressure and fob problem.
* Test key fob (most parts stores have a testing station), it could be a bad battery or more likely a bad fob (Common on older C5 fobs... search for key fob in the C5 section you will read up on it).
* Make sure you have TPMS (not all cars had them), should have metal valve stems on the wheels.
* TPMS has a battery inside each sensor in each wheel. Might need to replace the battery or the sensors. GMParts House, Parts Taxi and other supporting venders can sell you the new Sensors.
* Try reprograming the sensors:
http://www.vetteweb.com/tech/vemp_09...m/viewall.html
If you rotate your tires or replace a wheel sensor, your tire-pressure-monitoring sensors will need to be reprogrammed. The following is a step-by-step procedure for reprogramming the C5 sensors:
1. Let the vehicle sit for two minutes; then turn the ignition on.
2. Press the "Reset" button to clear any Instrument Panel Cluster (IPC) warning messages.
3. Press and release the "Options" button on the Driver's Information Center (DIC) and scroll through the display options until the IPC display is blank.
4. Press and hold the DIC "Reset" button for 3 seconds.
5. Press the "Options" button again until the "Tire Training" message appears.
6. Press the "Reset" button until the "Learn Left Front Tire" message appears on the IPC.
7. Place a large magnet over the left front valve stem. The horn will sound, indicating the left front TPMS sensor is programmed. If this takes more than 15 seconds, pull the magnet back and try again. If the procedure fails after three tries, you'll need to start the sequence over from the beginning. GM sells a special U-shaped magnet specifically for this job (PN J41760), but a large speaker magnet will usually work just as well.
8. When the horn sounds, the IPC will direct you to move on to the next sensor. (The sequence is left front, right front, right rear, left rear.) The programming can be canceled at any time by turning the ignition off. If the programming is cancelled with fewer than four sensors learned, it will only accept the sensors programmed up to that point.
The following is a step-by-step procedure for reprogramming the C6 Corvettes sensors. This procedure requires a wheel-sensor-reprogramming tool:
1--6. These steps are the same as for the C5.7. Install the wheel-sensor-reprogramming tool over the left front valve stem. The horn will sound, indicating that the left front TPMS sensor is programmed. If this takes more than 15 seconds, pull the reprogramming tool back and try again. If the procedure fails after three tries, you'll need to start the sequence over from the beginning.
Read more: http://www.vetteweb.com/tech/vemp_09...#ixzz2pBjGBioR
I had to pull mine and found the antenna was completely loose when i opened the case, took it to a radio shop and had it resoldered and have had no problem since then. My key fobs if they would sync would loose sync by the next day till i did this.
I also had 1 fob the was completelu dead a new battery for it didnt help so i got a new 1
Gl with your car i just purchased mine in sept 2013
