What is causing this engine noise?...
Old Jan 2, 2014 | 11:43 PM
Ed2016's Avatar
Ed2016
Default What is causing this engine noise?...
Does anybody know what is causing this engine noise in my C5?
It comes and goes randomly. I first noticed it about a year ago while my car was getting tuned. Then it popped up again last weekend.
I uploaded a video of it here on youtube:
http://www.youtube.com/watch?v=1EolP...ature=youtu.be
The only thing I've done on the car recently was change a squeaky idler pulley.
Thanks,
-Ed
Old Jan 3, 2014 | 12:35 AM
_r2h's Avatar
_r2h
Hidden supercharger?!
On a serious note, sounds like it would be something rotating on the front of the motor. Take off the belts and start the motor again, see if the sound comes back. Good time to feel the idler pulleys, see if they rotate smooth. I bet it's a idler, pump, or compressor on the front.
Old Jan 3, 2014 | 08:09 AM
fixvet's Avatar
fixvet
Could be a belt noise. Drip a few drops of water on the grooved side of the belts to see if it goes away. Could be another pulley squeaking too.
Good luck
Old Jan 3, 2014 | 09:29 AM
dadaroo's Avatar
dadaroo
Recommend you buy an automotive stethoscope and locate the noise. They are very inexpensive and quite effective. Sure sounds like a bearing noise or belt squeak. Should be easy to locate hopefully.
Old Jan 3, 2014 | 01:52 PM
warlock007's Avatar
warlock007
As stated, take belts off and start.
Sounds like a bad bearing in one of the accessory drives, AC, Power Steering etc. It could be deeper but always start with cheap and work your way unless you know exactly where it is. Stethoscope is defiantly a great thing to own.
To What is causing this engine noise?...
