Head and cam combo. 515 HP
There are 3 kits 485 HP, 500 HP, and the 515 HP, of course I only looked at the 515 HP kit.
Maybe buying this way saves some $$ vs buying piece meal, and time.
For some reason they do not give a new timing set, or lifters, I have read you might as well get new lifter buckets while your in that far.
What do you guys think about a setup like this?
http://www.trickflow.com/partdetail....0&autoview=sku
I know it's possible to reach 500rwhp with bolt ons as it's been done before, but I'm usually seeing low to mid 400's.
$3,299.97
On the summit site, it says the rockers are Harland Sharp, are those good?
The car is a 6 speed with 3.42 gears, I would most likely go to 4.10's while having the diff sent out to be updated for the extra power.
Sorry to hijack the thread. Curious what's so special with Trickflo kit mentioned. I can't imagine those heads would be that much better than the AI ported 243's. The cam isn't that much bigger than the one I plan to use.
But remember, that is heads and cam plus the other goodies mentioned. Unless you are going used, no way for aftermarket heads. Maybe the Patriots but I sure didn't read many good reviews of those.
I was also in contact with Mr. Mamo at AFR. His quote to do the same thing to my heads was a bit more $$$. I chose Advanced Induction because as far as the 243 heads go, thread after thread I read on his porting work to these heads, was positive and happy customers. Can't wait to collect all the parts and get it installed and tuned and report back with the results.
AI's price is $995 for the cnc porting and valve work. I'm getting their Heads/cam package which is $1800 I believe. That includes new springs, pushrods, head gaskets... I upgraded the springs to the Tooley dual springs with Ti retainers and Vitan seals. I also had Phil go ahead and provide the new lifters, buckets, timing chain, and his ported/blueprinted LS6 oil pump as well. I'm at around $2300 with them.
That looks like a pretty good value. GL with your results.
