Clutch options
Old Jan 9, 2014 | 03:23 PM
2000CorvetteFRC's Avatar
2000CorvetteFRC
Default Clutch options
okay i have a 2000 corvette FRC with 98k miles on it. the car is a H/C/I/Long tube car that makes 446 hp and 390 tq. and im looking at putting a 125 shot of nitrous on it later. i am getting oil coming out of the bell housing vent holes on the bottom so i suspect its either the rear main seal or the rear main seal cover gasket. so while i am in there i am going to replace the clutch kit, pilot bearing, slave cylinder, install a speed bleeder, replace the rear main seal and the rear main seal cover gasket.
now i have a ls7 clutch, pressure plate and flywheel in there right now with like 20k miles on it.
i was looking at the mantic single disk clutch but that is 1k bucks for everything and seems to be in the price range of twin disks
my question is what clutch should i go with?
Old Jan 9, 2014 | 03:46 PM
2000CorvetteFRC
there is also these i saw
RST
http://www.blu808.com/C5C6-Corvette-...its_p_224.html
RXT
http://www.tpsmotorsports.com/corvet...sc-clutch.html
Old Jan 9, 2014 | 06:15 PM
PRE-Z06's Avatar
PRE-Z06
Bang for the buck our Level 3 single disc can't be beat at $679.99 for the basic package with 28lb billet steel flywheel, but for a little more our LT1-S twin disc will hold almost as much and have stock driveability for $1099.99. Here's a link to it, don't hesitate if you have any questions.
http://forums.corvetteforum.com/c5-z...h-in-a-c6.html
Old Jan 10, 2014 | 02:03 PM
2000CorvetteFRC
bump
Old Jan 10, 2014 | 05:23 PM
Pchild's Avatar
Pchild
Any chatter on those clutches? I'm in the market for a new clutch this summer my stock can't hold my Boltons/Cam. I'm looking for stock feel that can hold 460ish RWHP, no chatter.
Old Jan 10, 2014 | 05:34 PM
dagon138's Avatar
dagon138
My McLoed RST makes noise sometimes when it's hot at idle with the clutch out.
Kind of a cyclic scraping sound.
From what I've gathered this is fairly normal on twin-disk setups on our corvette's and aggravated with light flywheels (mine is aluminum).
I've been told it can be masked by raising the idle, haven't tried it yet.
I do not consider that clutch chatter.
Old Jan 10, 2014 | 05:49 PM
2000CorvetteFRC
how do you like the RST? will that hold the power with no issues with making 446hp NA plus a 125 shot when i decide to hit it with NOS
Old Jan 10, 2014 | 06:47 PM
PRE-Z06's Avatar
PRE-Z06
The LT1-S is what I would recommend and it isn't going to chatter any more than the factory C7 clutch as that is what it is.
Chatter is generally caused by either fluid contamination or a glaze being built up from excessively slipped which causes an inconsistent mating surface between the disc, flywheel and pressure plate. It is easier to cause this with a ceramic friction material than an organic material, but not saying impossible. A lighter flywheel can cause this more easily as it generally takes more rpm to take off meaning more slippage with it's lower MOI. People also may associate it with aluminum flywheels because the steel inserts can warp with heat.
Old Jan 13, 2014 | 03:18 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The Mantic single ER2 is $755 shipped?
Old Jan 13, 2014 | 03:53 PM
2000CorvetteFRC
well i was pricing the mantic single ER2 with the slave cylinder, pilot bearing as well.
Old Jan 13, 2014 | 09:28 PM
Roger Z06's Avatar
Roger Z06
Spec 3+
$.02
To Clutch options
