Retrofit Tele Column
Old Jul 11, 2002 | 07:41 PM
Red Vert 02's Avatar
Red Vert 02
Default Retrofit Tele Column
Has anyone retro fitted their C5 with a power telescoping steering column ?My 02 Vert is a 1sa car and at 6'2" I could use the adjustable column. Any problems or headaches with the swap? Thanks for any info. :)
Old Jul 12, 2002 | 08:36 AM
Arnie's Avatar
Arnie
Cruise-In II Veteran
Default Re: Retrofit Tele Column (Red Vert 02)
I see you've decided to go ahead and swap columns, good luck.
ttt
Old Jul 12, 2002 | 11:36 AM
Red Vert 02
Default Re: Retrofit Tele Column (Arnie's C5)
From the zero response I've gotten to my questions, it looks like I'll be trying something that's never been done before. :eek:
Old Jul 13, 2002 | 07:13 PM
Red Vert 02
ttt
Old Jul 13, 2002 | 08:12 PM
Viprklr's Avatar
Viprklr
I am 6' 2" and have no problems getting out of my car. :confused: I have plenty of room to maneuver around. Now the 6' 5" and above guys I could see it maybe coming in handy. Why mess with the hassle and possible problems that may arise later? Just wodering. ;) :cheers:
Old Jul 13, 2002 | 09:01 PM
Skyguy^^'s Avatar
Skyguy^^
Default Re: Retrofit Tele Column (Viprklr)
Hey VPRKLR, A pair of Z06 rear brake scoops would look real cool on your FRC :yesnod:
[Modified by Skyguy^^, 1:04 AM 7/14/2002]
Old Jul 14, 2002 | 12:24 AM
ersatz928's Avatar
ersatz928
Default Re: Retrofit Tele Column (Skyguy^^)
It can be done, but you also have to have the BCM reprogrammed to add the power-telescope colum RPO (option code), so that it will be functional. It also requires that the car is equiped with a Seat Control Module (drivers side), which is present only if you have the seat memory option. The Colum telescope motor and switch connects to the Seat Control Module. If you dont have the memory option, you could just wire the telescope motor to a DPDT relay, set-up to reverse the polarity to the motor (in versus out). The relay coil is controlled by the "In / Out switch, and a second relay which applies power for either desired direction. Sounds more complex than it is, I can send you a schematic of this manual set-up.
Old Jul 14, 2002 | 12:29 AM
Skyguy^^'s Avatar
Skyguy^^
Default Re: Retrofit Tele Column (ersatz928)
I love this forum, with it anything is possible! :cheers:
Old Jul 14, 2002 | 02:31 AM
Viprklr's Avatar
Viprklr
hmmmm...maybe I will. Will have an updated sig pic in a couple of weeks. New tint, new wheels, and a little lower. :yesnod: :D :cheers:
[Modified by Viprklr, 12:31 AM 7/14/2002]
Old Jul 15, 2002 | 11:55 AM
Red Vert 02
ersatz928, thanks very much. That is exactly the info I need. Yes please send the schematic of the manual set up. My Vert is a 1sa base car without any memory functions, so I can wire it that way. Sorry I did not reply sooner ,but over the weekend I worked double shifts. A beautiful weekend and never got the Vert out of the garage. :)
Old Jul 15, 2002 | 12:03 PM
Red Vert 02
Viprklr, I can get in and out of the car OK with the tilt. The problem is my right thigh hitting the steering wheel when going for the brake. My '69 had the tilt and tele wheel and with less leg room than the '02 I could get a perfect driving position by pulling the wheel a little closer. If I tilt the wheel up to give me enough leg room it just doesn't feel right. I also think the Z06 rear brake ducts would look good on your car. :cheers:
Old Jul 15, 2002 | 02:47 PM
ersatz928's Avatar
ersatz928
E-mail a fax # to me and I will send you a schematic and parts list.
Old Jul 15, 2002 | 03:21 PM
Red Vert 02
You have mail. :)
Old Jul 9, 2015 | 07:47 PM
lambert55's Avatar
lambert55
Default Are you still around.
Originally Posted by Red Vert 02
You have mail.
I am hoping to find out what you finally did to get your steering wheel
to telescope, if you did. I have an 04 Z06 and I need to get the wheel closer to me when on the track on track days. David
Old Jul 10, 2015 | 07:58 AM
dadaroo's Avatar
dadaroo
If they don't get back to you I can help. I will need to know if you have Memory or not to start with.
I am not sure if the BCM needs to be programmed for the RPO or not. I can hook up my Tech 2 to my car and see if it shows up as an option. It may be if you have Memory and have a TSW it will work without programming. If you have Memory you should NOT need to have the BCM programmed to just manually change the position. I can verify with the schematics later. Have not looked at them in a while.
Mr. Sam
Old Jul 10, 2015 | 01:39 PM
lambert55's Avatar
lambert55
Default 04 Z06 Steering Wheel telescoping
I have memory on my drivers seat. I may not be understanding your question. I also have the settings for everything like trip meters, traction control, lighting and etc.
David
Old Jul 11, 2015 | 06:30 AM
dadaroo's Avatar
dadaroo
I asked the question since if you have Memory then you can have Memory control of a TSW if you want it since you have an SCM (not a Seat Relay Module) under the seat. It would be nice if the harness was there also. You could look under the existing column and check. I could provide the wire color and connector description on that.
The TSW is controlled by wiring that goes to the drivers seat. I recall the only exception is the ground.
To Retrofit Tele Column
