C5 wiring "dash"
Old Jan 17, 2014 | 03:50 PM
combatdoc's Avatar
combatdoc
Default C5 wiring "dash"
Hey guys I am working on a C5 drag car for a buddy and I need some wiring schematics for the gauges and for the light/turning signal switches. I guess all the dash wiring. The class he runs as to have stock gauges and he needs his headlight and turn signals. I would have left all the stock wiring in place but the car is using a aftermarket ECM and he has already pulled and cut interior harness. I am just trying to save alittle time and effort when wiring up all the stuff by not having to trace every single wire any help would be great, thanks
Old Jan 17, 2014 | 04:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
to get the correct schematics,,, you need to tell us the YEAR of the C5 that your working with. The harnesses and fuse boxes are year specific.
Do you have the BCM still in the car?
Old Jan 17, 2014 | 04:44 PM
combatdoc's Avatar
combatdoc
no BCM, its a 2000, 6 speed, I was planning on putting a relay for the headlights the turn signals and I need the inputs for the gauges, running a toggle for ignition, remote for start. all the sytems will be stand alone I just have a gauge cluster with the pigtail and a bunch of wires 8 inches long coming out of it, and the same with the turn signal headlight selector switch.
Old Jan 19, 2014 | 06:26 PM
combatdoc's Avatar
combatdoc
ttt
To C5 wiring "dash"
