C6 shifter install question
Old Jan 21, 2014 | 10:36 AM
04MSZ06's Avatar
04MSZ06
Default C6 shifter install question
I recently bought the C6 shifter kit from gmpartshouse. It looks like the **** has changed because when I try to install my Vette Essentials short shift boot, the boot won't cover the bottom of the ****. It looks like the new **** was designed to have a ring of some sort screw into the bottom of the **** to attach the boot. Will a C6 shift boot work in a C5? How can I make this work?
Old Jan 21, 2014 | 11:22 AM
CHJ In Virginia's Avatar
CHJ In Virginia
Different **** styles and different leather boots. I took the stock C5 boot , gathered it up and tied it to the C6 **** with a small Zip Tie. Not the most elegant method, but more than functional for a mostly track car. There is a forum vendor - I think that it is Vette Essentials - that was making custom shift boots for just this application. Do a search, there have been several threads on this subject over the past several years.
Old Jan 21, 2014 | 01:20 PM
Bluefire's Avatar
Bluefire
I've just been through this. I hunted for two weeks. Absolutely no one in the aftermarket makes this twist lock collar. The only way I could make it work with my Redline boot, and look correct was to order the cheapest boot from GM Parts House that contained the collar.
Old Jan 21, 2014 | 01:24 PM
04MSZ06's Avatar
04MSZ06
That's what I was afraid of. Do you know if the GM boot that contains the collar will work with the metal shift boot retainer like this:
http://www.ebay.com/itm/Shift-Boot-C...-/220850286432
(That's what I currently have).
Old Jan 21, 2014 | 01:54 PM
Bluefire's Avatar
Bluefire
I have the same ring. It works but you need to keep the "little bent out feet" as close as possible to the edge of the folded boot.
Old Jan 23, 2014 | 05:20 PM
YELLO C5's Avatar
YELLO C5
When I did the C6 shifter in mine I used the C6 **** and screw but reused my boot. There was a write up on how to modify the C5 boot but I can't find it now. It involved carefully separating the glued leather used around the hole in the C5 boot. Trimming it back a bit. Turning it inside out around the C6 **** and using steel wire to attach the boot to the base of the ****. Turned out great. Looks stock with the C6 **** which I much prefer over the C5.
Old Jan 23, 2014 | 06:11 PM
1BADAZ50TH's Avatar
1BADAZ50TH
I found my boot and **** at Vette Essentials as mentioned above. Did not come with the screw for the ****. Was special order at stealership. Great quality on the boot and ****, easy install.
To C6 shifter install question
