Wierd oil problem
I rolled down the window to listen to the echo off of the car next to me, and there was no indication of lifters clacking or rods knocking. I shut it off, and checked my oil, and the dipstick had no oil on it.
I checked it again, and sure enough, no oil.
I walked to a nearby gas station, and bought some oil, walked back and added 3 quarts.
Started the engine, and had 55 PSI of oil pressure.
then drove to a Auto Zone, and bought 2 quarts of Mobil 1, and added it.
I was kicking myself the whole way home......How could I have missed this?
When I got home, I checked the dipstick, and I was 2 inches above the fill line!
has anybody got an explanation for this?
A few questions:
When did you last change the oil?
When did you last check the oil level?
Has there been any work done under the hood?
Dannyman
I get out, pop the hood, check the oil, and according to the dipstick, it's full. I look around, there are no visible leaks. It's getting both dark and late, so I push the car into the garage, both dis-heartened and puzzled. Next day, I drive my old car to work, and all that day, I'm thinking of what could be wrong. I get home, jack the car up pull the oil filter, and cut it open. Don't see anything wrong...get another filter off the shelf, fill it with oil, and install it. I check the oil, and again, the dipstick shows it's full.
I then pull the coil wire, spin the engine over, and within a couple of seconds, the oil pressure gauge jumps up to normal. Put the coil wire back on, fire the engine, and for the next 5 years, the car ran just fine.
Go figure......It happens!!
Did you check the oil level before adding the last 2 qts?
Maybe you were ~3 qts low. If there was only 2.5 qts in pan, I doubt you would be able to maintain a solid oil press.
Low oil quantity message should have appeared when you were just over 1 qt low.
Maybe that sensor isn't working correctly.
I usually have water temp displayed on the DIC.
big gun your an imbecile if that's all you can come up with.
I thought it couldn't be low, that's why I checked it twice.
I drained the excess oil out, and changed the oil filter in case it had some problem.
oil pressure is still 55 cold and around 48 hot.
drove it to work Sunday night and again today. no problems whatsoever.
watched the heads up and the gauge, and not a glitch.
I changed the oil pressure sender about 2 years ago. no oil problems till this.
Just a side note, the water temp is around 175 normally in the winter with the right amount of oil. I have a 160 thermostat.
with the extra oil, the engine barely got to 163
It is 13 years old and 66,000 miles. normally in a go to work style of driving, it probably never sees 3500 RPM.
I usually check it hot, because that is what is probably in the pan when it is running..
The sensor by the filter is for the oil level. The low pressure message can be caused by the pressure sensor behind the intake. It can fail and read zero and the low pressure message will appear, mine did.
Ref the bottom right corner of the attach image.
The image was used to show an oil leak, but it does capture the low oil level sensor.
http://www.digitalcorvettes.com/foru....php?p=1990516
I try to follow what the manual says:
- warm up the engine ( I like normal operating temperatures )
- vehicle parked on flat level surface
- shut-off engine and wait 3 minutes minimum
- clean dipstick and fully insert, keep tip down and check level
I try to repeat this anytime I check the oil.
I'm guessing you're going to keep an eye this for your next few rides. The last time I had low quantity it turns out the drain plug wasn't tight. This didn't happen on the vette; but I was still less than impressed!
If you're losing oil it can only be one of two things; it's leaking or consumed. Keep on eye on it and let us know what you find.
Dannyman
1. Engine failure from insufficient lubrication
2. Idiot light illuminating telling me to put oil in
If you'll notice, step 3 of the procedure in the manual says to let the engine sit for ~3 minutes. In that 3 minutes, most of the oil will drain back down to the pan. The difference in the measurement then v/s the following morning will probably be < 1 cup of oil and not even measureable on the dipstick. Try it yourself if you don't believe me. Why GM says to warm up the engine first I have no idea. Perhaps to accommodate for thermal expansion?
I have. It makes a difference and the reason is in the design of the LSx engine. The design engineers would not have gone through the trouble of making sure this information was included in the owner's manual otherwise.
