Streetable suspension setup inquiry
Old Feb 6, 2014 | 09:53 AM
DBOTHEBOSS's Avatar
DBOTHEBOSS
Default Streetable suspension setup inquiry
Hey guys,
I rarely ever track my 01z...I am looking for improved handling that will not sacrifice much in terms of ride quality.
Right now, I am considering lowering slightly on bolts (my Z sits relatively higher than other stockers) along with the JOC stage 1. I think coilovers would be overkill considering this is for the street and that I don't need adjustability.
I have heard mixed reviews about lowering on bolts, stock or extended. Would slightly lowering on bolts along with the JOC1 make my ride much rougher.
does anyone have this setup? If so, please share your experience.
I live in DC but it's not my daily. I just don't want to take cruises out to the rurals and find myself clinching my jaw over the minor stuff.
Old Feb 6, 2014 | 11:34 AM
RedZMonte's Avatar
RedZMonte
lowering a little should hurt the ride quality, you wont see a big difference unless its slammed all the way down on stock/aftermarkt bolts. the shocks will make it a little firmer depending on what you have in there now and how old/miles are on them. I know alot of members here have C6Z06 Shocks and C6Z51 sway bars and are very happy with the setup. the JOC STG1 should still be very streetable and give a little better performance then the C6Z/C6Z51 setup. From what i understand the 04 C5Z Sachs Shocks are stiffer then both of thoes and my car rides fine I think. If I were going to change my suspension out I would also run the JOC setup.
S
Old Feb 6, 2014 | 11:37 AM
DBOTHEBOSS's Avatar
DBOTHEBOSS
Sounds good. Thanks for the advice. I've thought about some of the c6z upgrades as well. Just to confirm, lowering a bit on stockers *shouldn't negatively affect ride quality?
Anyone else with this setup?
My car only has 25k miles on it so the stock stuff is in really good shape.
Old Feb 6, 2014 | 12:52 PM
Cybermind's Avatar
Cybermind
Keep in mind that any lowering of the ride height will have some effect on the ride quality. This is because you are reducing the shock absorbers's travel distance and changing the suspension geometry. You will also need a re-alignment after lowering and this can also affect the ride quality. Whether it will be significant or not will depend on you and how sensitive you are to your car's ride characteristics.
My setup is the following:
Stock height
Bilstein HD shocks
Eibach antisway bar kit with poly bushings
New endlinks
For me, this is the perfect compromise between handling and comfort. It may or may not be too tame for you. Probably Bilstein Sports would be more suitable for slightly lowered Z-cars.
Old Feb 6, 2014 | 01:06 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree, however, I like to observe stuff, and to my observation, I don't think I've seen any two C-5s at the same ride height. Therefore, it's difficult to make a blanket statement like, "lowering a half inch should be OK", since you don't know the starting point.
I'd take a measurement from the center of the bolts at the inner pivot point of the a-arms to the ground (on a level surface), front and rear, and post those numbers here. It would give you, as well as the rest of us, a valid point of comparison.
Old Feb 6, 2014 | 02:48 PM
Bluefire's Avatar
Bluefire
The Factory Service Manual states you can lower the car 1/2" and still be fine.
Old Feb 6, 2014 | 04:22 PM
Lbandt's Avatar
Lbandt
Cruising
id throw some shorter bolts in and , maybe an upgraded shock? or just leave the shocks and springs alone and do larger sway bars and poly bushings. that will help more and ride quality wont change
Old Feb 7, 2014 | 08:40 AM
leadfoot4's Avatar
leadfoot4
"Shorter" bolts will RAISE the ride height, and poly bushings will KILL the ride quality.....
Old Feb 7, 2014 | 09:58 AM
Lbandt's Avatar
Lbandt
Cruising
My bad.. was thinking one thing and said another lol and i was speaking of just the swaybar bushings. I should have clarified
Old Feb 7, 2014 | 02:51 PM
leadfoot4's Avatar
leadfoot4
Got-cha......
Old Feb 7, 2014 | 03:17 PM
RedZMonte's Avatar
RedZMonte
Nice thing about the suspension is its relativly easy to adjust. so set it how you like it and give it a whirl, you could allways raise or lower it if you dont like it.
If you get a bar with poly pushings make sure they are greasable and alot of guys wrap the bar in teflon tape where the bushing rides to keep it from squeeking. A good rubber bushing will work great for the street or if you can find a "Delrin" bushing they are self lubericating so they are not supposed to squeek. I would still put a little dab of grease on the bar to keep it quiet with whatever bushings you get.
S
Old Feb 7, 2014 | 08:25 PM
ericdwong's Avatar
ericdwong
I can mostly relate- I have a base C5 but started out with z06 springs. I have it lowered all the way on the factory bolts WITHOUT cutting bushings or getting longer bolts. I felt that the car had too much body lean (granted, I had the stock sways, not the Z51 or Z06 sways). I went with Hotchkis swaybars and Koni FSD shocks, tunnel plate stiffener and had the alignment shop do a Z06 alignment. Really happy with the results :-) Didn't cost an arm and a leg, and still get even tire wear with awesome handling.
Also, if your car has alot of miles, consider replacing all of your ball joints and tie rod ends. I replaced mine with Moogs (at a different time than the bars, springs and shocks) and that too made a difference.
I had poly control arm bushings too but I got rid of those- too harsh.
Old Feb 7, 2014 | 09:55 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
I was torn between the joc and the C6Z shocks but ended up going the C6Z route with the C6Z51 sways and lowered on stock bolts, that with a fresh alignment and the addition of 18/19 wheels with larger tires, made the car Handel 100 times better and to be completely honest I have never noticed a difference in ride quality. I'm not slammed by any means but I have to be diligent in how I approach various obstacles.
I think either way you go that you will be very happy
You can see from this pic I'm not a 4 wheel drive anymore but not slammed as they say either.
Old Feb 8, 2014 | 11:58 AM
lionelhutz's Avatar
lionelhutz
Here's a post with details on how to measure the ride height and what stock should be.
http://forums.corvetteforum.com/c5-z...de-height.html
That can help you gauge where you are now and how much you may want to lower below the stock ride height.
Old Feb 8, 2014 | 12:26 PM
Corvette_Ed's Avatar
Corvette_Ed
My setup is similar except I'm still running on the stock shocks and wheel/tire sizes. After I lowered my car all the way down on stock bolts I noticed a huge improvement in handling, but the ride itself was much more rough. I'm hoping new shocks will cure that, but it's something the OP should keep in mind.
To Streetable suspension setup inquiry
