How to fix half shaft?
Old Jul 13, 2002 | 07:02 PM
DALE C's Avatar
DALE C
Default How to remove & replace half shaft?
I broke the output shaft in my rear end and the piece is still stuck in the half shaft. I've already got the rear end out and the new output shaft in, but I'm having trouble getting the broken piece out. Any ideas?
[Modified by DALE C, 5:07 PM 7/13/2002]
Old Jul 13, 2002 | 07:11 PM
DALE C's Avatar
DALE C
Default Re: How to remove & replace half shaft? (DALE C)
I need to know how to remove and replace the half shaft so I can get the broken piece out.
Old Jul 13, 2002 | 07:14 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Dale, I read your post... when mine was fixed, (the left internal shaft was broken) I was not there to witness the removal... sorry I can help you out... :(
vetterdstr :chevy
Old Jul 13, 2002 | 07:59 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Dale, you might pester The One. I believe I recall him mentioning this issue when he had his repaired also, maybe he knows a trick or two now. :)
Old Jul 13, 2002 | 08:25 PM
C5Noir's Avatar
C5Noir
Default Re: How to remove & replace half shaft? (ToplessTexan)
Yo uhave to disassemble the entire rear end to get the half shaft out :(
Old Jul 13, 2002 | 08:34 PM
DALE C's Avatar
DALE C
Nevermind, I got it out without removing the half shaft. Thanks!
Old Jul 13, 2002 | 09:12 PM
ToplessTexan
Don't be such a tease! :jester Was there cleverness involved or was there actually enough sticking out to grab onto?
[Modified by ToplessTexan, 7:14 PM 7/13/2002]
Old Jul 13, 2002 | 09:55 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In III Veteran
Cruise-In VI Veteran
What's with all the questions Kurt? Some things are better left unknown! :D
Nick
Old Jul 13, 2002 | 11:57 PM
The One's Avatar
The One
They had to drill through mine to then put a bolt they could grab onto to pull it out. Charged me an extra half hour of labor for that. :rolleyes:
JC
Old Jul 14, 2002 | 01:22 PM
ToplessTexan
Default Re: How to remove & replace half shaft? (Smoke-N-Shot)
Habit. ;)
Old Jul 15, 2002 | 08:28 AM
Smoke-N-Shot
Habit. ;)
I know... :D
Nick
To How to fix half shaft?
