Z06 exhaust swap
Old Feb 8, 2014 | 10:28 AM
88redconvert's Avatar
88redconvert
Default Z06 exhaust swap
Will a C5 Z06 exhaust bolt right up to a non Z06 C5? If so what is the advantage and will it be louder?
Thanks for any info
Old Feb 8, 2014 | 11:25 AM
dadaroo's Avatar
dadaroo
Yes you can, a friend of mine did it to have a better sound and loose some weight. It is best done on a lift since you need a lot of clearance. Any muffler shop can help you if you don't have access to a lift.
Old Feb 8, 2014 | 11:47 AM
lionelhutz's Avatar
lionelhutz
The catback is worth swapping but the rest isn't.
Old Feb 8, 2014 | 11:56 AM
vettenuts's Avatar
vettenuts
Didn't the Z06 exhaust eliminate the pup cats? Not sure on this but if so it might help a bit with less restriction.
Old Feb 8, 2014 | 12:18 PM
RedZMonte's Avatar
RedZMonte
The muffler has less chambers, larger internal piping and are made of Titanium (super lite weight). They sound a little deeper/louder then base mufflers, weigh quite a bit less then base mufflers and will not restrict power like base mufflers (not a lot of gains of stock engines.. Ti mufflers are good for up to Aprox 500whp. The Ti mufflers sound good especially with LT headers... Not to loud and no drone.
The Z06 02+ does not have pup cats only a pair of primary cats, but it would require LS6 exhaust manifolds as well. I dont think they Hpipe is a straight swap without them... someone else can verify but i think the flanges are in different locations/angles. (i could be wrong on this). From what i understand the cats will not cost you any power (or very minimal if they do). The manifold is a 4-2-1 design rather then a 4-to-1 like the LS1 has but not really worth the swap unless you are wanting to keep it as Stock as possable with minimal upgrades.
Z06 Ti mufflers are usually going for around $300-$400 for the pair the manifolds and Hpipe are basically worthless to most people so can be had for next to nothing ($50-$100).
S
Old Feb 10, 2014 | 10:55 AM
88redconvert
Do you know if this is a straight bolt-on?
thanks
Old Feb 10, 2014 | 11:50 AM
craig-o's Avatar
craig-o
thanks
Yes. I did it on my 2001 convertible; no modifications whatsoever.
As was said earlier, you need to get the car up pretty high (I've been told at least 36") so the exhaust will clear the rear-end; so you'll want access to a lift. Then, just a few bolts on the exhaust and muffler hangers and you're done. Once it was up in the air, it took less than 15 minutes with hand tools.
To Z06 exhaust swap
