driverside firewall hole?
Old Feb 10, 2014 | 05:25 AM
seansz28's Avatar
seansz28
Default driverside firewall hole?
is there anywhere on the driverside firewall to run a small tube from the engine bay for a mechanical boost gauge
Old Feb 10, 2014 | 06:19 AM
Cutlassmaster's Avatar
Cutlassmaster
I put a small hole through the hood release cable grommet when I installed my gauges. Then used some RTV to ensure it was sealed back up.
Chris
Old Feb 10, 2014 | 06:36 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
You can also go around the top of the door pillar and under the weatherstripping to behind the dash which is easier and doesn't require any drilling.
To driverside firewall hole?
