Are these injectors useable?
Old Feb 10, 2014 | 09:58 AM
rttmike's Avatar
rttmike
Default Are these injectors useable?
I just bought these from another member and they arrived looking pretty rough. I'm not sure if I should even bother using them. There are parts of the end of the injector cracked and missing. What do you think? Without a doubt I will replace the o rings.
Old Feb 10, 2014 | 10:01 AM
Patches's Avatar
Patches
Pics?
Old Feb 10, 2014 | 11:19 AM
rttmike's Avatar
rttmike
Umm, I have pictures posted
Old Feb 10, 2014 | 11:28 AM
Derf's Avatar
Derf
I would buy new and toss those. They are a pretty important part to screw around with. My two cents.
Cutlassmaster's Avatar
Cutlassmaster
I see the pics and looks like the plastic on the bottom of the injector that helps retain the O-ring is what is cracked/broken. You can probably get some more through someone that cleans/rebuilds them. Looking at it you would probably be fine to run with new O-rings.
Chris
Old Feb 10, 2014 | 11:38 AM
rttmike's Avatar
rttmike
I was looking online for new parts but can't seem to find them. I am pretty upset that a seller here would send these.
Old Feb 10, 2014 | 11:54 AM
Patches's Avatar
Patches
Strange - they don't show up for me at all.
Regardless, the words "cracked" and "injector" do not belong in the same sentence as far as I'm concerned. Never put you motor at risk with compromised critical components. Injectors are relatively cheap so buy a good used or new set. I think I have an almost brand new, pristine set in storage I pulled off at 3k miles when I installed my FMS 36 lb. injectors a while back and I'm about to pull those in favor of the 60 lb. units my new setup needs.
Old Feb 10, 2014 | 12:01 PM
Dcollins3208's Avatar
Dcollins3208
Try searching for a pintle cap, the purpose of that plastic part is to hold the o-ring in place. You may as well get a whole rebuild kit (o-rings, pintle caps, and filters) while you're at it. Very easy to replace all!
Old Feb 10, 2014 | 12:03 PM
rttmike's Avatar
rttmike
How much do you want?
Old Feb 10, 2014 | 12:04 PM
rttmike's Avatar
rttmike
I will do that. But any idea how to know I am getting the correct ones?
Old Feb 10, 2014 | 12:07 PM
Dcollins3208
What's the p/n on the injectors?
Old Feb 10, 2014 | 12:12 PM
vettenuts's Avatar
vettenuts
I bought a used set and shipping them to New Era Performance in NY for cleaning and flow measurements. They looked new when I got them back. Give them a call and find out what they think. Mine also came back with the flow sheets and while they are all pretty close to each other I put the one with the highest flow in #7.
Old Feb 10, 2014 | 12:14 PM
rttmike's Avatar
rttmike
This is what is on them.
Part# 0280155811
Old Feb 10, 2014 | 12:39 PM
Dcollins3208
This is what is on them. Part# 0280155811
Here ya go http://bit.ly/1kw7ExZ
I used these guys parts to rebuild my SVO red tops. Ask them if they have a package of 8 bc their packages are much cheaper
Old Feb 10, 2014 | 12:48 PM
rttmike's Avatar
rttmike
Dude you rock!
But I don't see the plastic keepers. Do you think they are included?
Old Feb 10, 2014 | 01:27 PM
Dcollins3208
Dude you rock! But I don't see the plastic keepers. Do you think they are included?
If you look to the right they are there, they are clear in color
Old Feb 10, 2014 | 01:34 PM
xzo124's Avatar
xzo124
Thats what im talkin about . Somebody was in DYER need of some COIN.....xzo
To Are these injectors useable?
Old Feb 10, 2014 | 01:50 PM
rttmike's Avatar
rttmike
I emailed him. I have yet to hear anything.
Old Feb 10, 2014 | 01:54 PM
Patches's Avatar
Patches
I have picked up rebuild kits at NAPA in the past. Not sure of the price but the convenience of having them down the street made it worth it to me.
Old Feb 10, 2014 | 02:27 PM
88redconvert's Avatar
88redconvert
I have a set from an 01 Z06 that look brand new compared to those.
number 12561462. They are listed on the C5 parts forum.
