shock life
Old Feb 14, 2014 | 11:00 AM
myjoedee's Avatar
myjoedee
Default shock life
Hi,
I have a 97 with 42K miles on it. What is the expected life of the stock shocks? I know they ware out slow so one would not really notice if they are getting bad unless they are really weak. Mine seem fine but thought I would check to see if age more than mileage would ware them out.
Thank you,
Joe
Old Feb 14, 2014 | 11:22 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
99 6mm 148,000 miles original standard shocks. no leaks, still firm ride,no bounce. Original owner. I guess it depends on the driver and the quality of the shocks in materials and manufacture. Road quality is also a factor in longevity
Old Feb 14, 2014 | 11:54 AM
dadaroo's Avatar
dadaroo
You should be fine like the The Big Guy says if you have no issues. If you replace I recommend you consider the C6 ZO6 shocks. Much better performance and not expensive. GMPartsHouse has great deal on them. Hope I got their name right.
Old Feb 14, 2014 | 11:56 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Rule of thumb for me when buying a used car if I don't know how old the shocks are.
10 years or 40k miles. Leaks or no leaks, all four are replaced.
After that, they're replaced after two sets of tires or 50K miles.
Shocks wear and lose their capacity to perform just like tires.
The difference is that tires show their wear and shocks don't unless they leak.
Old Feb 15, 2014 | 07:13 PM
DWC4's Avatar
DWC4
Recently purchased an '03 true Ann Ed with the MRSC shocks, which are leaking. So I looked at your suggestion, sounds good, part # c6z06shocks is $265 at http://store.gmpartshouse.com, that is a set of 4 for the 2012 Z06 they say fits our C5's. I've read about disabling the controls so the car doesn't get the errors etc from the lack of the MRSC signal. Anyone have experience on how easily these actually install and ride?
Old Feb 15, 2014 | 07:44 PM
racebum's Avatar
racebum
i typically replace around 10-11 years. if any are leaking or seeping they are done for
Old Feb 15, 2014 | 08:32 PM
JrRifleCoach
[QUOTE=DWC4;1586182392Anyone have experience on how easily these actually install and ride?[/QUOTE]
Installation is straight forward, nuts and bolts.
Took a ride in a friends that we installed these in.
Work great. Will take a few miles to knock the newness off.
Old Feb 16, 2014 | 12:23 PM
DWC4's Avatar
DWC4
Great. I'll begin the search for a garage with a Tech II whose willing to disable the MSRC so I don't get the 80MPH limit. THANKS.
Old Feb 16, 2014 | 12:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The STOCK C5 shocks loose a lot of performance after 30,000 miles. Unless, they totally fail, you will not be able to feel it in the car. If you follow a C5 with worn shocks, you can see it fail to dampen properly over bumps and road undulations.
If you install the C6 ZO6 shocks and drive it, you will need a crow bar to pry the grin off your face. My 02 ZO6 would side step (jump towards the outside of the curve when the road was rough) when I would take a fast highway sweeping turn onto the highway.
After the installation of the C6Z shocks,, that issue was resolved!
The C6Z Shocks are a 100% OEM replacement and no problem fit. Collapse the new shocks and ZIP TIE or coat hanger wire them in the collapsed position. Remove the old shocks, bolt the bottom in place, cut the retainer wire and guide the top into place. Bolt in.
Thats all there is to it. Gene Culley at GMPARTSHOUSE can hook you up with them for a great price.
Enjoy the IMPROVED ride!
BC
Old Feb 16, 2014 | 01:20 PM
Darrell98's Avatar
Darrell98
I agree. What a difference ! I changed mine soon after I purchased a 98 Convertible. I also went with the C6 Z06 shocks from GM Parts House. Direct bolt on.
Old Feb 17, 2014 | 08:32 AM
myjoedee's Avatar
myjoedee
Sounds like I may be changing my shocks. Will the C6 ZO6 shock change the ride hight or give me a hard ride?
Thank you,
Joe
Old Feb 17, 2014 | 10:14 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You're OEM C5 shocks were originally gas charged. A shock has little or NO effect on a cars ride height. HOWEVER,,, The GAS pressure in the shock does provide some lifting force on the suspension.
If you compress the NEW shock on a bathroom scale, the force that it takes to compress the shock to about 3/4 compressed, will be the amount of lift on each corner of the car.
So,, yes, there will be a little added lift but, any new gas charged shock will do the same.
As for harshness. I was able to feel a little more road irregularities but, nothing to complain about. The performance improvements will FAR make up for that.
Old Feb 17, 2014 | 11:10 AM
123Gone's Avatar
123Gone
I have an '02 C5 with 80K miles. I just replaced all shocks with C6 Z06 shocks. I didn't realize how worn out the fronts were until I replaced them.
Old Feb 21, 2014 | 01:43 PM
tytek's Avatar
tytek
Gasoline Addict
Replaced mine on my Z06 at 60k miles and the difference in ride and performance was profound. I could have very easily pushed the piston back into the used shocks by hand after taking them out. Not so much on the new ones.
Went with C6Z06 one for under $250 delivered. Great mod for the track.
Old Feb 22, 2014 | 12:24 AM
jcgunn's Avatar
jcgunn
I replaced the OEM at 9yrs/80K with Bilsteins mostly 'cause the car was on the rack and I was getting the 10yr 100K service stuff done all at once. Can't say I noticed THAT much of a difference...
To shock life
