Magnecor Spark Plug Wires
Old Jul 14, 2002 | 01:14 PM
Xssesive's Avatar
Xssesive
Default Magnecor Spark Plug Wires
I recently did a run using buddy's autotap, showed a few misfires in no.2 + 3 cylinders. Having installed NGK 55's a month ago I figure it's the stock wires. Went to http://www.thunderracing.com cheapest place I could find for both Magnecor and Thundervolts($69.95) went ahead and ordered Magnecor's although Angie at Thunderracing said they do have problems if you are going to be taking the wires on and off a lot. Told her my plan is not to so I went ahead with the purchase. Anybody have this problem? After visiting http://www.Magnecor website I am pretty much sold that these wires are as good if not better than any wire out there. Any feedback would be helpful. :crazy:
Old Jul 14, 2002 | 01:45 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Magnecor Spark Plug Wires (Xssesive)
It is the wire that LPE uses!!!!!!!!!! :seeya
Old Jul 14, 2002 | 01:48 PM
Jim 47's Avatar
Jim 47
I've had them for over a year now and I do think they are better than any of them out there! :cool:
Old Jul 14, 2002 | 01:59 PM
Albert Chlouber's Avatar
Albert Chlouber
We have had good luck with the Magnecor wires on Vipers also. The only problem is if used with NGK plugs, the boots sometimes stick and you have to be real careful pulling the boot off or the inside will rip out.
Old Jul 14, 2002 | 02:07 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
I used the magnecors on my 2000, and loved them. Plan on putting them on my 01 when I get a chance. They use the stock delco boot on the plug end, so that works great, and also allows you to use the heat shield.
Old Jul 14, 2002 | 05:36 PM
wwashing's Avatar
wwashing
Default Re: Magnecor Spark Plug Wires (Albert Chlouber)
Are you using Di-electric Silicon gel when replacing the boots? This should keep them from welding to the plugs :cheers:
To Magnecor Spark Plug Wires
