UGH! turn signals
Old Feb 16, 2014 | 10:35 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default UGH! turn signals
I just replaced my hazard light switch and my hazards and brake lights work again, but I still don't have turn signals. ugh! Also when I pull the turn signal lever up or down, I don't hear the relay clicking. its whisper quiet when I pull the lever up and down.
Is there a fuse for the turn signals?
Old Feb 16, 2014 | 01:56 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Mine does that. Turn on a signal and just wiggle the hazard button side to side and see if the signal starts blinking. If so you got a defective switch
Old Feb 16, 2014 | 11:29 PM
All_Motor_C5LS6
I don't see how the hazard switch is defective as I have just replaced it with a new Hazard switch and now have my brake lights back and my hazard lights work.
I think I might have to replace my turn signal switch lever on the steering wheel or try the hyper flash from JW Motoring.
How would I know if it is the headlight/cruise control/turn signal stalk lever that is bad?
Old Feb 17, 2014 | 11:43 AM
thundertruck's Avatar
thundertruck
Yes, there is a separate fuse for the turn signals. It is a 20 amp fuse in position #15 of the fuse panel according to the FSM wiring diagram. If that fuse is OK, you could have a defective hazard switch. Here is a link to another post with instructions on the easy way to replace the hazard switch if that is the case.
http://forums.corvetteforum.com/c5-t...placement.html
and another with some nice photos.
http://forums.corvetteforum.com/c5-t...-shortcut.html
but check fuse 15 first, since it is the most likely cause. It is in the instrument panel fuse box, under the passenger's side toe board.
Last edited by thundertruck; Feb 17, 2014 at 11:59 AM. Reason: additional information
Old Feb 17, 2014 | 11:57 AM
dadaroo's Avatar
dadaroo
What was your specific issue(s) that caused you to replace the Hazard switch? I have resolved numerous similar issues for Forum members.
I agree that it could be as simple as Fuse 15. Here is the schematic. The Hazard function uses a different fuse.
Old Feb 17, 2014 | 04:01 PM
All_Motor_C5LS6
fuse #15 is hazard/turn signal. if it were blown the hazards wouldnt work right?
what are the syptoms of a failed headlight/cruise control/turn signal stalk lever? could that be it?
Old Feb 17, 2014 | 05:59 PM
dadaroo's Avatar
dadaroo
NO, look at the schematic. If you can't read schematics trust me and TEST the fuse.
You still have not answered the question I asked you.
Old Feb 17, 2014 | 11:45 PM
All_Motor_C5LS6
Problem solved! turned out to be a blown fuse (#15). My turn signals are working again, Thanks for all your help guys!
Old Feb 18, 2014 | 08:31 AM
dadaroo's Avatar
dadaroo
Glad it was so simple. A lot of people get fooled when they see that schematic and the "wording" on the fuse which is very misleading. However the schematic tells no lies in actually what that fuse provides.
PS: You may have a short problem that will blow the fuse again. Hopefully not, and it was just tired and gave up. If you blow it again let us know if we can help.
To UGH! turn signals
