Took off intake, now AC mixer not working
Old Feb 16, 2014 | 11:50 AM
aggiedave98's Avatar
aggiedave98
Default Took off intake, now AC mixer not working
I took the intake off to replace the oil pressure sender and now have taken the intake off 3 times to try and fix the vacuum leak. Finally found out it was the tiny line going into the MAP sensor.
I hooked that up (had to do it by feel) and am pretty sure I had it connected, but the AC blower mixer won't change vents still.
Where does that line that goes into the MAP hook to? Could I have pulled that out? How do I trouble shoot this?
I don't have any codes. The idle is maybe a tiny bit rough.
The sound of the vacuum leak is not as loud as it was before I hooked that up.
Thoughts on where to go from here?
Old Feb 16, 2014 | 12:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The line is TOUGH to get it to stay in the little boot that it goes into. Either you didn't get it in properly or its BROKE somewhere inside the wire harness.
I extend mine and glued it into the rubber boot to make reinstallitation easier.
The line goes down to the passengers fender well and connects to the vacuum reservoir. You can test the vacuum there with the engine running
Some re-run a new line and be done with it. It doesn't have to be run inside the main wire harness but, it makes it like factory.
Battery acid can and will dissolve the line inside the harness. So,,, see if you see any signs of past battery acid leakage.
Bill
Old Feb 16, 2014 | 12:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres the extended line.
Here is the connections in the passengers fender well:
Old Feb 16, 2014 | 04:22 PM
aggiedave98
Awesome! Thanks so much. But where is this? It seems like this would be easy to spot, but I don't see it.
Is this something I can do without taking off the intake again? When I put that hose back on, I did it with the intake slid back a little in order to reach in there.
Old Feb 16, 2014 | 04:37 PM
aggiedave98
Ok, found where you meant:
https://www.aacorvette.com/pdf/aa_c5_pcm_removal.pdf
I'm guessing it pulled out. Where can you get that thin plastic vacuum line if I want to make it longer? Did you run a new one all the way from the tank to the manifold? Do they have it just at the auto store? What is it called? Thanks again!
Old Feb 16, 2014 | 06:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check NAPA ,, Advanced Auto and Advanced Auto
They all should have a Nylon line repair kit and the line
BC
Old Feb 16, 2014 | 07:40 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Advance Auto, NAPA and Autozone all should have a Nylon Line Vacuum Line Repair kit and or the raw vacuum line for sale.
I just added a length of line to the short OEM piece that was provided. Made a big difference.
Old Feb 16, 2014 | 08:16 PM
k24556's Avatar
k24556
Mine got brittle from heat and cracked behind the right cylinder head. I replaced the line with 1/8 rubber all the way back to the vacuum canister. Even though a pita, easier with the intake removed
Old Feb 18, 2014 | 09:46 AM
aggiedave98
Bill, how did you join it together? And what kind of glue did you use?
k24556, Any tips on how you routed and secured it?
One last question... What is that large (1.5-2" diameter) hose with a rubber "bulb" on the end? Mine is cracked open completely.
Old Feb 18, 2014 | 10:03 AM
Cutlassmaster's Avatar
Cutlassmaster
Usually you can just use a piece of rubber vacuum line to join them together. Your other question sounds like the PCV system is in need of some TLC.
Chris
Old Feb 18, 2014 | 10:44 AM
aggiedave98
Cutlass, thanks. What is that rubber bulb called and where is it hooked up to?
Old Feb 18, 2014 | 11:03 AM
Cutlassmaster
Can you post pics to make sure I or anyone else is not steering you wrong? What year is your car? Has anything ( intake, valley cover, valve covers etc) been replaced/upgraded?
Thanks!
Chris
Old Feb 18, 2014 | 12:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The nylon line repair kit comes with an assortment of fittings and line splices that are easy to install. You just insert the two lines in the repair coupler and use a heat gun to shrink in place. Mine has never come apart of had any issues.
If you dont extend the line, you are missing an opportunity to make LS engine maintenance easier.
There are THREE common nylon vacuum line diameters. Take a small piece with you and get the correct size line. I also uses a small thin coating of BLACK RTV to afix the nylon line into the the small 90deg rubber boot. Be careful and dont use TOO MUCH and clog the line or fitting when you insert it.
Call NAPA. They most always have unique and hard to find stuff like that. My 07 BMW K1200R Motorcycle takes a unique off brand blue colored antifreeze ( PENTOFROST N ) They had it!
I got my repair kit from ADVANCE Auto but Ive see the same type kit at AutoZone. Ask the counter man for help.
Well,,,,,,,,,, I did some research for you and I sort of struck out at all three places (locally). NAPA sells a 5/32" vacuum line ( part# 2-672) but I believe that the vacuum line we have is smaller.
Find some used vacuum line the same size, use a razor blade and cut the ends 90 deg clean and use some quality heat shring tubing with adheasive inside the shrink to join the two hoses together. Any electronics store sells it.
Just heat shrink it together.
BC
Bill
Old Feb 18, 2014 | 12:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OK,,,,,,,,,,,,,,,,,, Found it at CARQUEST.
7/64" X 6 feet for $4.39 They also have some fittings to connect it.
Good luck
Bill
Old Feb 18, 2014 | 12:16 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
To Took off intake, now AC mixer not working
