I was catless for a couple years. After too many head aches & tired of the exhaust stink, I installed the LG metal cats. NO MORE STINK! No tuning will stop the stink in a catless vehicle, and the bigger the cam, the greater the stink.
Russ Kemp
Thank you, finally a tuner agrees with me.
Been saying this on various boards for a while now and everyone is so stubborn about it.
YOU CAN'T TUNE IT OUT! You can play with end of injection timing, run open loop and command a lean idle all you want, but the stink will remain and it sticks to every thing.
The best solution I found was to command a RICH afr, so at least it smelled like an old carbed muscle car instead.
Stock cammed cars are mostly ok, it smells good actually. But even cams with -5 overlap stink horribly.
A lot of it has to do with the cam and the tune. I have the older ceramic coated mild steel TSP headers and X pipe on my 00 and with a 228R cam and tuned by Lashway Motorsports in S Florida there is no smell at all.
