hyperflash bypass install problem
Old Mar 8, 2014 | 10:32 AM
demon81's Avatar
demon81
Default hyperflash bypass install problem
I'm installing a hyperflash bypass unit.I'm having a problem removing the iats cover plate to unplug to access the screw behind it.It keeps catching on the front dash panel.don't want to force it .Any tips or info from previous installs would be greatly appreciated.It doesn't mention removing the center console cover, but i think i might have too.I'm using the instructions downloaded from the RadioFlyer site where I purchased the bypass unit.
Old Mar 8, 2014 | 12:51 PM
LoneStarLizzard's Avatar
LoneStarLizzard
Here are instructions from Vette Essentials ("VE") re: how to remove the radio bezel, etc.: http://www.vetteessentials.com/instr...zel_howto.html
If you will follow these instructions all the way through step 4, or step 5 if you decide to remove the driver's side knee bolster, these instructions should fix you up.
And here are instructions from JW Motoring's website as well: http://www.shop.jwmotoring.com/C5-LE...ashHarness.htm
If you do want to remove the radio bezel and have an automatic transmission, you'll need to remove the AT shift ****, which is a special step also covered in the VE instructions.
The Lizzard
Old Mar 8, 2014 | 12:53 PM
LoneStarLizzard
Demon81, if you will fill in the profile information found in your user profile, you will help the rest of us give you more precise instructions.
The Lizzard
Old Mar 8, 2014 | 02:05 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Step 4 of my directions should help out
Old Mar 8, 2014 | 05:37 PM
demon81's Avatar
demon81
thanks for the info gentlemen, slow and steady and I was able to remove the cover.rest of the install went well.DLR switchbacks with led running lights look awesome.
To hyperflash bypass install problem
