Hi, I have codes and need help
Old Mar 10, 2014 | 01:42 PM
jasonlau8023's Avatar
jasonlau8023
Navigator
Default Hi, I have codes and need help
Hi all,
I am very new to here. Recently i bought a 01 corvette coupe and havent done emission test. There are some engine codes and my mechanic said i should fix those codes before emission test. here are the codes:
P0713
P0740
P0748
P0753
P0758
P0785
P1810
P1860
I googled and it seems they are all related to transmission. I heard it may related to electric power to the transmission failed. but i absolutely have no clue where to look. could anyone here have details how to fix those codes? thank you all so so so much!
Old Mar 10, 2014 | 01:49 PM
3boystoys's Avatar
3boystoys
You posting the same question MULTIPLE times won't help get you an answer faster.
Old Mar 10, 2014 | 01:51 PM
jasonlau8023
Navigator
sorry i thought the previous ones not posted successfully so i posted twice more. how can i delete those twos? sorry im very new here
Old Mar 10, 2014 | 02:34 PM
3boystoys's Avatar
3boystoys
Trans codes should not fail you on emissions. Where are you located? Most states don't even check tail pipe emissions, just I/M monitors via the OBD port.
Old Mar 10, 2014 | 02:43 PM
jasonlau8023
Navigator
thats what i thought too. im in toronto, canada. but anyway i still need to fix these before driving without worry. thanks.
Old Mar 10, 2014 | 02:58 PM
3boystoys's Avatar
3boystoys
As stated before, clear them ALL and see what (if any) return.
Old Mar 11, 2014 | 03:45 PM
jasonlau8023
Navigator
yes i tried. those codes came back immediately when i started the car.
Old Mar 11, 2014 | 04:01 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First start with the fuses in the engine fuse box. Check the fuses for the transmission.
Does your transmission even shift correctly with all thosDTCs?
Old Mar 11, 2014 | 04:10 PM
jasonlau8023
Navigator
my transmission is manual, what you mean those codes must be applied to auto? or maybe i bought a car with manual conversion? holly.....
im gonna check fuses. thanks bery much!
Old Mar 11, 2014 | 04:16 PM
3boystoys's Avatar
3boystoys
Check the options on the label on the backside of the glove compartment door.
Old Mar 11, 2014 | 05:21 PM
Russ K's Avatar
Russ K
I would call GM with your vin to see if it was originally an auto trans. If so, then it would be best to flash a manual trans tune into the pcm. Or maybe someone installed a used pcm from an auto equipped car.
Russ Kemp
Old Mar 11, 2014 | 06:03 PM
jasonlau8023
Navigator
Russ Kemp
ok i guess i got a auto car with manual conversion. any idea how i can clear those codes? pcm module change?
Old Mar 11, 2014 | 06:17 PM
jasonlau8023
Navigator
Russ Kemp
because the 11th postion of my vin is 5. so i can almost certain my car was auto transmission originally.
Old Mar 11, 2014 | 06:22 PM
Russ K's Avatar
Russ K
You could delete all codes for the auto pcm file with Hp Tuners. But there are some unique & hidden tables for the manual pcm files that aren't available with Hp tuners. Your best option is to flash a stock manual trans file with Hp Tuners or with a Gm Tech II TIS. But you will need to find a suitable manual trans vin, and the emission inspector may require the pcm & vehicle vin's to match.
Russ Kemp
Old Mar 11, 2014 | 06:23 PM
jasonlau8023
Navigator
Russ Kemp
can i ask more detail about how to flash a manual trans tune into the pcm? only dealership can do that right? cost?
Old Mar 11, 2014 | 06:34 PM
jasonlau8023
Navigator
Russ Kemp
got it. thanks very much! can i ignore those codes and still get emission done? those methods are really too complicated. the car is great its just check engine light on and really worry the emission wont pass with emission light on. big headache!
Old Mar 11, 2014 | 08:54 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
All your codes except po713 are type A or B codes. They are listed as emissions related. Only p0713 is listed as a type C non emissions related. Type A and B will turn on the mil. Type c will not.
I agree with RussK. Reflash the PCM with an m6 file. Do it before your emission inspection. If they pull the codes and are aware they are related to an auto trans, they may fail you for tampering. They might also check to see if the vin in the PCM matches the vin on the dash plate, tampering if not?
To Hi, I have codes and need help
