Pass. side headlight motor
Old Mar 10, 2014 | 05:55 PM
bobby777's Avatar
bobby777
Default Pass. side headlight motor
has the strip gear sound only when closing--took apart and the gear is good--any suggestions?
Old Mar 10, 2014 | 09:40 PM
bobby777's Avatar
bobby777
If its not the plastic gear--what--anybody?
Old Mar 11, 2014 | 12:46 PM
Cybermind's Avatar
Cybermind
The only other thing that can cause that condition is the motor housing coming loose and separating from the gear housing. This would cause insufficient contact between the jack screw (worm gear) the actuator gear. Check your motor housing. Make sure it is properly seated and the four pins are still holding it on.
Old Mar 11, 2014 | 02:31 PM
bobby777's Avatar
bobby777
I have it out--looks like new and the plastic gear looks new--someone said something about a module that lets the motor run for afew seconds after the lights are down--if it lets it run why would it make that famous loud rattle sound?
Old Mar 11, 2014 | 03:59 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Also check to see that you have 4 white bumpers on each headlight assembly. The stop the travel and provide the resistance that turns off the headlight motor.
To Pass. side headlight motor
