DIC Malfunction
Old Mar 15, 2014 | 03:42 PM
RDSJ's Avatar
RDSJ
Cruising
Default DIC Malfunction
Has anyone found a fix for a non-functional DIC? Mine works on the system inputs (like a cruise control speed setting) but does not respond to any of the control buttons on the right side of Inst Cluster.
2002 Quicksilver Z51 Conv
Old Mar 15, 2014 | 05:15 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Can you pull the codes, or is that not functioning either? If not you will need a good scan tool that can communicate with all the modules to pull the codes. Otherwise trying a different switch would be an easy test. When the switch is unplugged,there should be at least 6 terminals with less than 5.0v at the connector. If you don't, don't buy a new switch.
Old Mar 15, 2014 | 06:12 PM
RDSJ's Avatar
RDSJ
Cruising
There are no codes set. The car performs fine and all other functions work except the commanded DIC functions.
Perhaps it is a common problem, pertaining to the switches, i.e., power, ground, pwb problem or other. I know several people have had the problem and I post every 6 months or so to see if anyone has identified a cause.
To DIC Malfunction
