How do you ....
Old Jul 16, 2002 | 02:28 PM
Lucien's Avatar
Lucien
1st Gear
Default How do you ....
A stupid question but I know the answer is out there. I got the Breathless metal gas pedal and dead pedal. I can't seem to get the dead pedal removed from the car. I have removed the two nuts but the dead pedal doesn't want to come off. Genrerally I break things by using too much force and in trying to remove the dead pedal I'm using enough force where I'm worried about breaking the plastic. Is there a trick I not using? Thanks for any help. :confused:
Old Jul 16, 2002 | 02:32 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: How do you .... (Lucien)
got mine out right now.....work from the bottom pulling it towards the center of the car, it will eventuall pop out....the top bolt, although facing the rear of the car has a slotted hole that it fits into and that gives it some flex while pulling the bottom out the opposite direction :cheers:
