1997 ebcm
Old Mar 17, 2014 | 10:05 AM
Vette97sc's Avatar
Vette97sc
Default Did -99 ebcm work in -97 vette?
I get dtc 1255 EBTCM Internal Malfunction in my -97 vette. I find ebcm from -99 model car. Did that work in -97 car? -97 ebcm is rear of car and -99 its front of car. Both ebcm have M code and without active handling.
Old Mar 17, 2014 | 11:50 AM
dadaroo's Avatar
dadaroo
That code is normally the "death" code for the module. Check the connector for any issues and maybe you'll get lucky.
Looked at the parts manual and the 97 seems unique and not interchangeable with any other year.
Old Mar 17, 2014 | 02:30 PM
Vette97sc's Avatar
Vette97sc
I check connetors already and they look fine. Have to look again grounds. Dtc 1255 is not always on. Look like i get that under hard acceleration.
He say 97-00 is same ebcm even locate different place.
http://forums.corvetteforum.com/c5-p...-handling.html
Old Apr 20, 2014 | 12:15 PM
Vette97sc's Avatar
Vette97sc
I change ebcm from -99 car. Its work fine in -97 model. I only need one small brake line part from old ebcm. Now abs and tc working and i dont get any dtc codes anymore.
Old Apr 20, 2014 | 01:41 PM
Narco944's Avatar
Narco944
You should post a write up on changing it
To 1997 ebcm
