Bilstein sport shocks and rear squeak
Looking for advice!
Bilstein sport shocks on the car. The problem started right after they were installed. I have a high pitched squeak coming from the back. it takes only a slight suspension travel to make the sound, so its noisiest on relatively smooth roads.
it comes from the upper mounts. when it starts Ican spray some lube on the area of the upper mounts and it will stop. sometimes for a day, sometimes for a month.
I posted about this once before. Iwas given the advice to support the rear suspension with a jack while torquing the bolts. that didn't fix it for me. I also tried tightening them more, no good.
they were assembled according to the supplied instructions which were pretty vague. the nuts on top were tightened just until it started to squeeze the bushings.
looking for any input to make this noise stop! thanks!
I hate to break it to you but you were supposed to tighten the top nut until the bushings are squeezed to about the same size as the washers in which they are sandwiched. That is quite a bit more than "just until they start to squeeze". Seems to me your top nuts are loose. Easy fix if that is the case.
thanks for the help! I'll try to carve some time out this weekend to pull them off again. That part is pretty easy at least.
Hope this helps
No.........do not tighten the nut down to the end of the thread travel! You need to tighten the nut only until the rubber bushing (diameter) is squeezed out to approximately the same size as the washers. This means that it will be compressed to about half its original thickness when you are done. Too much tightening may damage the rubber bushing.
Hope this helps
Hope this helps
