headlight problem
Old Mar 19, 2014 | 09:10 PM
demon81's Avatar
demon81
Default headlight problem
last week I installed the DRL with switchbacks and Led strip.The new look is amazing.Thanks RadioFlyer.I did numerous checks of the lights and everything worked as it should.Tonight i backed the car out to put some items in the attic.The car idled in the driveway for roughly 10 minutes.When I pulled it back in and turned on the running lights one more time the headlight buckets also popped up but didn't light up untill I turned the headlights on . when I turned the headlights off they lowered, but the drivers side has a sound like the motor is stuck and runs for another 5 to 10 seconds.nothing appears to be hanging up on the headlight housing. My first concern is the lights coming up when I turn on the running lights.No idea where to start.it's a 99 vert.
Old Mar 20, 2014 | 05:51 AM
jamieo's Avatar
jamieo
Sounds like the gear is stripped.It will make your headlights do all kinds of weird stuff
Old Mar 20, 2014 | 06:01 AM
Cybermind's Avatar
Cybermind
A stripped headlight motor gear. It's fairly easy to repair yourself. Just make sure you buy the brass gear replacement kit. I recommend you do both headlights because it's just a matter of time before the other one fails.
Old Mar 20, 2014 | 10:24 AM
demon81's Avatar
demon81
thanks for the info, hopefully that's all it is.I can't imagine having one of these cars without having the forum to turn to.
To headlight problem
