C5 T56 output shaft question.
Old Mar 20, 2014 | 03:36 AM
turbotarzan's Avatar
turbotarzan
Cruising
Default C5 T56 output shaft question.
I'd like to mount a transfer case behind a C5 T56. For this I would need a very short outputshaft. The questions are; Is the splined part of the shaft thicker, thinner or the same as the smooth part of the shaft? Can I continue the splines on the smooth part and cut the shaft to desired length?
The T56 I'm looking to buy is from a m.y 2000 c5.
