Staring issue - starter? solenoid?
Old Mar 21, 2014 | 01:47 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default Staring issue - starter? solenoid?
I’ve been suspecting the battery in my C5 was on its last leg for a while, and last night and this morning it was having trouble starting. So I went to O’reilly’s and grabbed a new battery and installed it. When trying to start the car and holding the key all the way to the right it tries to crank but very weakly, same as with the old battery. Sometimes if you hold the key long enough it will start, and sometimes it won’t and you’ll get some smoke come up and a strong metal/burning smell.
Starter? Solenoid?
Thanks in advance!
Old Mar 21, 2014 | 10:35 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Post up some codes if possible. A few things come to mind that could be giving you troubles.
Old Mar 21, 2014 | 10:52 PM
BigGun's Avatar
BigGun
Check the connections at the starter. If they get loose or corroded they get hot and fry causing the issues you have described.
Old Mar 22, 2014 | 12:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% ON THE MARK!
Same I replied in the PM!
To Staring issue - starter? solenoid?
