crank bolt
Old Mar 22, 2014 | 05:37 PM
Blow Torch's Avatar
Blow Torch
Default crank bolt
Are you guys able to tighten your crank bolt while the engine is on the engine stand, and if so, HOW??
Old Mar 23, 2014 | 07:16 AM
HardcoreABN's Avatar
HardcoreABN
flywheel/flexplate lock
Old Mar 23, 2014 | 08:59 AM
Blow Torch's Avatar
Blow Torch
It will take a LOT to hold it when applying over 200lbfts to it.
I was hoping some engine shop guys would chime in...
Old Mar 23, 2014 | 09:44 AM
vettenuts's Avatar
vettenuts
Wonder if that might be worth doing once its back in the car.
Old Mar 23, 2014 | 10:27 AM
HardcoreABN
bolt the flywheel/flex plate on then bolt on a flywheel/flex plate lock. then torque it down as necessary, it will not move. If you look around, you can get 1 for $35.
Old Mar 24, 2014 | 08:43 AM
Blow Torch's Avatar
Blow Torch
Have you used one of these before?
I'm being ****, but it seems like it would need a few more teeth engaged to hold that much torque.
Who sales them?
Vettenuts
That's actually why I was asking; I was afraid I would turn the engine stand over even if I could get it locked.
Old Mar 24, 2014 | 08:13 PM
RonSSNova's Avatar
RonSSNova
Use that tool, or some other tool to hold the flywheel.
Get a pipe for your breaker bar.
Have a friend hang on to the stand. It won't be hard.
Or get a Scoggins dickey or arp bolt that isn't tty
To crank bolt
