Titan TPMS
Old Mar 23, 2014 | 07:32 AM
mmaynard's Avatar
mmaynard
Default Titan TPMS
I purchased a Titan replacement TPMS sensor for one that failed on my 2001 vert. No matter what I tried the car would not recognize it. I had a tire dealer confirm the sensor was transmitting. Titan had me take all of the air out of the tire several times, re-inflate it, and again try to re-train the sensor. They told me to move the old sensor 100 feet away from the car. At one point the tech suggested that I remove the rear wheel and move it closer to the BCM so it would pick up the signal. I spent two days working on this without results. I did confirm that I was shipped the correct unit. Yesterday I ordered a Schrader OEM replacement. I will end up spending the $25 I saved in buying a cheaper TPMS on having the tire removed and the Schrader installed. Lesson learned.
Old Mar 28, 2014 | 07:13 PM
mmaynard's Avatar
mmaynard
I received a new Schrader TMPS sensor today. It trained on the car on the first attempt. I did test the Schrader sensor outside of the tire. The car recognized it and reported the tire as being flat due to the sensor being outside of the tire. I emailed Titan about this issue but they did not respond. Once I swap the sensors in the one tire this weekend I will return the Titan TPMS.
Old Apr 4, 2014 | 09:22 PM
This is good information. Thanks for providing your feedback on the various tire pressure sensors that are out there.
Old Apr 5, 2014 | 06:16 PM
Vettegreen#98's Avatar
Vettegreen#98
Really appreciate the advice! Thanks...
Old Apr 7, 2014 | 11:26 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Do you have a link for the Shrader or part number, their web page is blocked here at work
Old Apr 28, 2014 | 03:43 PM
TitanTPMS's Avatar
0TitanTPMS
Former Vendor
mmaynard,
Im sorry that no one got back to your email. Please call me and I will get you taken care of.
Old Feb 8, 2015 | 01:41 PM
cheryl451's Avatar
cheryl451
1st Gear
Default titans work
put two titan tpms in my 2000 and used a speaker magnet to train them.
working great
To Titan TPMS
