Larger Maf Ends?
Old Jul 17, 2002 | 11:19 AM
Phil97SVT's Avatar
Phil97SVT
Default Larger Maf Ends?
Has anyone installed larger MAF ends and noticed a increase in HP? I am starting to analyze the little systems to see if I can gain a few extra ponies at the wheels. The MAF Ends and TB are my current items I am trying to maximize. Thanks!
:cheers:
Old Jul 17, 2002 | 11:23 AM
Chris@SD's Avatar
Chris@SD
Default Re: Larger Maf Ends? (Phil97SVT)
They are really not bottle necks in the system. I would leave them alone. The ones that are seeing an increase withe TB ends are just leaning their car out by making the car think it is getting less air than it thinks...
Until you get in the large cube, high reving stroker category, I would leave the TB alone also.
Good luck,
Old Jul 17, 2002 | 11:31 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: Larger Maf Ends? (Chris@SpeedDemon)
Chris,
Any ideas where I can pick up some more ponies? Injectors, Gears, TB, MAF, Ends, plugs, ect?
Phillip
Old Jul 17, 2002 | 01:15 PM
luvinc5's Avatar
luvinc5
If you are looking for the mods to boost hp without breaking into the motor, then you are limited to mods that make air intake easier and exhausting better. So having said that, check into Blackwing air filter, removing the screen in front of the MAF, LS6 intake, long tube headers and aftermarket exhaust.
Old Jul 17, 2002 | 01:25 PM
ZippoMan's Avatar
ZippoMan
A fellow member said in a previous post that Mark Shaner's TBs are by far the best ones out there. He only charges $139 (with core) so it may be worth a shot. Considering you're pushing a lot more power at the wheels than stock, I think you would probably see some kind of power increase. His website is http://home.att.net/~m.shaner/wsb/ht...ome.html-.html.
Old Jul 17, 2002 | 01:36 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
I picked up about 4-5 rwhp with the Katech ported throttle body..........
Old Jul 17, 2002 | 01:42 PM
ddawson's Avatar
ddawson
I use the larger MAF ends. My butt FELT a difference between the stock MAF with no screen and the larger MAF ends.
Chris is right though because on warmer days I'd get knock and had to use the MAFT to add back some fuel. It was running lean 5%.
I need to get back to the Dyno to see if the MAFT added or subtracted HP in any way.
Old Jul 17, 2002 | 01:45 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Larger Maf Ends? (luvinc5)
Umm.... :lol: :lol: :lol: :lol: :lol: If you have not checked out my sig, check it out now. I am way past air filters and exhausts. I am looking for the small mods to add hidden HP to a 421rwhp car.
Phillip
[Modified by Phil97SVT, 5:46 PM 7/17/2002]
Old Jul 17, 2002 | 01:50 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
With all your mods, I think you could see some peak HP, with a ported polished TB, no MAF screen, and bigger ends. Especailly if you dial it all in with LS1Edit.
[Modified by kewlbrz, 11:51 AM 7/17/2002]
Old Jul 17, 2002 | 09:14 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Larger Maf Ends? (kewlbrz)
The MAF is a calibrated device. In your case I would pick up an 02 LS6 maf and use put in the 02 LS6 MAF table in your pcm with ls1edit.
Eric
Old Jul 17, 2002 | 09:54 PM
Vettepartz's Avatar
Vettepartz
I removed my screen, cut the dividers, and blended ALL rough edges, including the ridge where the screen was. My LTFT's were 8% lean, so I adjusted the MAF table to compensate for it. Bear in mind, this is a C5 with the straight shot of air from the cleaner. It may not be a big gain in HP, but it's FREE. With a lot of the bolt-ons costing 15 to 50 bucks per HP, What have you got to lose!
Old Jul 17, 2002 | 11:08 PM
ToplessTexan's Avatar
ToplessTexan
Default Re: Larger Maf Ends? (66ImpalaLT1)
I don't know how precisely or accurately calibrated the stock set up is, but it's got to be better than a random combination of MAF ends and sensor. I won't even get into the GMS piece... :rolleyes:
I believe you will need to resample the xfer function for the later MAF... I believe the '02 table has more points than the '97.
Old Jul 17, 2002 | 11:14 PM
luvinc5's Avatar
luvinc5
Phillip
I suppose I should turn the signatures back on.
Old Jul 18, 2002 | 12:01 AM
66ImpalaLT1
Default Re: Larger Maf Ends? (ToplessTexan)
99-00 should have the same number of data points. Phil has a 99 :D
Eric
Old Jul 18, 2002 | 01:01 AM
ToplessTexan
Phil has a 99 :D
:bb
Bed time for me I guess...
Old Jul 18, 2002 | 01:36 AM
ToplessTexan
Maybe I'm not losing my recall after all... Here's a snippet from one of KenK's responses on the ls1edit mailing list in late March regarding the issue of this swap:
List-Archive: <http://www.ls1edit.com/pipermail/ls1edit/>
X-Original-Date: Sun, 24 Mar 2002 16:34:57 -0500
X-Status: N
THe 98 LS1 reads to 11250 Mhz
THe 99 LS1 reads to 12000 Mhz
THe 01 LS1 reads to 12000 Mhz but adds some additional points on the low
end
YOu should be able to create a new MAF file for the 01 MAF, but it
won't be a direct copy. THe low end of the curve has a finer step size,
and lower starting value in the 01.
Ken
Tom Garland wrote:
> Ken -- does the table being larger mean that it extends past 12000 or that
> it includes more data points along the way to 12000? With that said, do you
> think it will be possible for me to use LS1Edit to calibrate my 2000 data
> table to work with this larger MAF?
> Ken -- the new features list looks great! Keep up the excellent work! I
> for one am anxious to see the gear scaling and hopefully some additional
> idle controls in the future (enrichement, IAC, etc.)
> Thanks Again
> Tom
Old Jul 18, 2002 | 02:32 AM
66ImpalaLT1
my bad :bb
To Larger Maf Ends?
