Steering column lock -.-
Old Mar 27, 2014 | 01:43 AM
paloalto00's Avatar
paloalto00
Default Steering column lock -.-
So my 00`s column just locked up after a week of owning the vehicle. I checked the battery charge and it's at 13 Volts which seems to be about right. I'm wondering if there's any other fixes besides taking it to the dealer, I was suppose to take her down to L.A this weekend!
Old Mar 27, 2014 | 02:23 AM
paloalto00's Avatar
paloalto00
Originally Posted by 8VETTE7
If the 13 volts was read from the dash gauges with the engine running then you are reading the output voltage of the alternator. Dash gauge readings for voltage CANNOT tell you the state of health of the battery. They tell you the state of health of the charging system. Since the column lock function runs long before the engine is started having voltage AFTER it has run is to late. Voltage reading on the gauges with engine off and key on is useless as there are many electrical circuits loading the battery with the key on.
Measure the Noload battery voltage. That is measured with the neg battery cable disconnected and directly across the battery posts with a digital multi meter. The car will start with a Noload voltage of 12.2 or less. However the electronics in the C5 are not happy with a Noload voltage of 12.5 or less, especially the column lock related electronics.
Is the car an automatic or manual trans? Makes a difference. I suggest that you get and install a CLB or LMC5 to prevent getting stranded by the column lock function. If you have a manual trans then the PCM has been reprogrammed to have a 2mph fuel shutoff speed. That means that the column lock function could strand you in two ways, locked column or fuel shut off if the BCM thinks the column is locked when it should be unlocked. Either the CLB or LMC5 is a permanent fix for the column lock symptoms. You have a personal experience that proves that the GM solution is NOT a permanent fix.
I wouldn't consider taking it to a dealer unless you have very deep pockets. AND if the real problem is the battery, the dealer repair will fail again very quickly and perhaps not in your driveway.
The car is a manual. I don't think CLB will help right now since my column already locked (My car is stranded off base)
Old Mar 27, 2014 | 02:50 AM
paloalto00's Avatar
paloalto00
NOT the case!!!! The CLB comes with an unlocker tool (from most sources but not all) and you can purchase an unlocker when you purchase an LMC5.
You MUST unlock the column BEFORE you can install either.
Here is a technique that can also unlock the column:
http://forums.corvetteforum.com/show...ghlight=unlock
May take a strong arm but the technique usually works. Try more than once if necessary.....
How fast do you think the CLB can get to me?
Old Mar 27, 2014 | 03:02 AM
paloalto00's Avatar
paloalto00
You might be able to get one shipped overnight but it won't be inexpensive if you do.
Further on a 99 or 2000 manual trans you need to bypass the Column Lock Relay in the passenger footwell to have a CLB function correctly.
Here is the info on bypassing the Column Lock Relay:
http://Forums.corvetteforum.com/c5-t...installed.html
Then scroll to post #15
Contact this Forum Vendor and see if he can help you out:
http://www.southerncarparts.com/adva...Bypass&x=0&y=0
I'm already confused, do you think the LMC5 would be easier? I just watched a video on how to do it and it seems pretty straight forward
Old Mar 27, 2014 | 03:23 AM
paloalto00's Avatar
paloalto00
Might work but read this thread for possible problems you might run into:
http://forums.corvetteforum.com/c5-g...-corvette.html
Pay attention to post #16......
Check your PM's
So I just checked my car again, and the volt is at 11, is that a sure sign to change the battery
To Steering column lock -.-
